General a cure for rust?
warrington
by any chance does anyone no how to stop rust and how to get rid of it?
as ive got it in my wheel arches and im wanting to stop it before it causes to much damaged that new plates need to be welded on and all that.
also how do you get a rear bumper off a cinq sporting?
thanks kris:D
yup, once its started you will never get rid of it unless you replace that section of metal. and even then it will probably come back.
As said, you can only slow it down and temporarily prevent it, but if you forget about it ital return!
grind back as much of the rust as you can to bear metal. then apply some hammerite krust. then antirust primer over the top and apply the top coat. should do the job nicely :)
rust is lighter than metal why you want rid?
imo rust is the new carbon fibre
