Old 25-05-2006   #1
Trader Rating: 1
Luke has donated!
George Wants Beer Champion, Home Run Champion
Front Lower Wishbones
Hi all,
Anyone changed their front lower wishbones? Any pitfalls / things to look out for etc.. ? Plan on putting these babies on tomorrow weather permitting
Luke is offline Reply With Quote Quote
Old 25-05-2006   #2
hi friends :waves:
Liam's Avatar
Liam has donated!
Re: Front Lower Wishbones
Custard has but he's sleeping now, peaster2k did a great thread/guide on them IIRC.
Liam
Yes it's really me!
97 Cinq Sporting-RIP 09/10/06 BYE OLD FRIEND
Liam is offline Reply With Quote Quote
Old 25-05-2006   #3
Trader Rating: 1
Luke,
I have had my wishbones off a few times now, the haynes tells you more than enough. Once your under the car it is quite simple. Watch out for rusty bolt if they have not been off before.
Quick Guide:-
Jack Car Up
Remove Wheels
Remove ARB completely
Break Lower Wishbone Ball Joint apart after removing the nut.
unbolt wishbone & brackets from car
Then reverse of above. Lots of cooper slip when you put everything back together. When you come to do up the lower wishbone nut, place a jack under the lower wishbone and compression the suspension slighty, I found this helped. This can also be used when doing up the ARB as well, only once both wishbones are back on the car..
HTH
David
Edit, so i did Liam, how I forget. https://www.fiatforum.com/cinq-sei-t...rm-bushes.html & Few Photos:- http://smg.photobucket.com/albums/v4...ster2k/Bushes/
My ebay items: http://search.ebay.co.uk/_W0QQfgtpZ1...Zpeaster2kQ5f1
peaster2k is offline Reply With Quote Quote
Old 25-05-2006   #4
Trader Rating: 1
Luke has donated!
Ah good, sounds like an afternoons work inc. teabreaks/swearbrakes Just what i like to hear. Now all i have to count on is the weather
edit: I assume the ARB mounts are removable so i can transfer them onto my new arms?
Old 25-05-2006   #5
Trader Rating: 1
Luke,
I would probably say the worst part is spilting the ball joints if they have been together for years like mine had the 1st time round.
HTH
David
Old 25-05-2006   #6
Trader Rating: 1
Luke has donated!
Quote Originally Posted by peaster2k
Luke,
HTH
David
Ok cheers, think there should be a balljoint splitter in the garage. Infact i know there is as thats what i used to remove the OEM outside bush from my new arms i'll let you know how i get on
Regarding removing the other bush, a long thread, bolt, few washers and a 32mm socket worked wonders. Took 2 minutes each bush to push out
Old 25-05-2006   #7
hi friends :waves:
Liam's Avatar
Liam has donated!
Your biggest problem is rusty stuff shearing so get the release oil on.
Liam
Yes it's really me!
Old 26-05-2006   #8
Autotest Special
rallycinq's Avatar
Trader Rating: 1
rallycinq has donated!
Quote Originally Posted by Luke1985
Yup, spot on
D
Old 26-05-2006   #9
Status: DEFCON Grumpy
custard's Avatar
Trader Rating: 1
custard has donated!
im awake
well i had a problem with mine as one of the ARB/wishbone bolts holes was mis threaded so had to re tap the thread.
also on the arb end mounts on both sides the 13mm bolts sheared on removal so i just replaced the end mounts and also one centre ARB mount as another bolt sheared. fiat dealers just up the roads so easier than the scrappies.
not a big job,i just seem to have poor luck when i do this type of job lol
Old 26-05-2006   #10
Trader Rating: 1
Luke has donated!
Quote Originally Posted by custard boy
im awake
lol, know the feeling. Got up nice and early ready to make a start and it's been raining all day, so given up. Going to re-concrete my garage floor now so i can do all these types of job under shelter
Old 26-05-2006   #11
custard's Avatar
Trader Rating: 1
its not a difficult job.mine was made so by snapping arb mounts and fooked threads.
mines has 90k on it so these things happen
Old 26-05-2006   #12
Trader Rating: 1
Luke has donated!
Yea, Im toying with replacing all the bolts i can with stainless ones anyway But as rain stops play ive had to find something else to do, so been working on my website (which now has just broke too ) Will have a try Sunday if weathers not too wet.
Old 26-05-2006   #13
im awake
this has also happened no my cinq pissed me right off.
cinqing is offline Reply With Quote Quote
Old 26-05-2006   #14
Autotest Special
rallycinq's Avatar
Trader Rating: 1
Do not use stainless bolts on suspension, under any circumstances.
They are too brittle.
D
fiat 850 - Lowering Front Suspension? MorganGT 850 19 03-06-2012 13:07
Die Hard!!! The Negotiator Leisure Lounge 27 24-04-2006 22:20
(S) Front Spoiler / Rear Deffuser / Side Skirts MoDiFiEd Punto (Mk2/2b) 6 04-04-2006 15:42
(T) Play in front Antiroll Bar Link Arm Rich Stilo 2 04-07-2004 01:26
