dont think the timing on the engine will be out coil is a electronic so it should work any1 know anyway of testing the coil without putting it on another car?
as long as they are the same design its fine.one is probably original and the other has been replaced at some time.
this is why i like having 2 cinqs as it makes testing parts easy as oyu just swap them over
i got it running now :slayer: it was the wire that goes to the crank sensor 1 of the three was damaged inside the conecting block and it fired up first time :slayer: :slayer: :slayer:
