Garf Green Goblin Parked in the garage Joined Mar 26, 2006 Messages 160 Points 63 Location Burnley May 19, 2006 #1 put a univeversal induction kit on my car but dn't knw wot to do wiv the airflow sensor anyone know? does it perform any different without it? by the way my cars a sei sporting spi Cheers
A arc this is where i stand Parked in the garage Joined Oct 8, 2003 Messages 19,719 Points 3,335 Location Manchester May 19, 2006 #2 doesn't have an airflow sensor, has a manifold pressure sensor instead.
OP OP Garf Green Goblin Parked in the garage Joined Mar 26, 2006 Messages 160 Points 63 Location Burnley May 19, 2006 #3 so why does that sensor go to the original airbox then? does it effect the performance at all?
A arc this is where i stand Parked in the garage Joined Oct 8, 2003 Messages 19,719 Points 3,335 Location Manchester May 19, 2006 #4 what sensor, you mean the vacuum operated switch for hot / cold air ? You'll find a vacuum line running the throttle body on there, not a wire.
