![]() | #1 | ||
Posts: 6 Thanks: 0 Trader Rating: 0 | ![]() Hi Guys Is it only me or did they design the Seicento Speedo warning lights in a bad location or what, mines smack bang behind the steering wheel and I can not see any of the headlight or indicator warning lights. Is the steering column adjustable and I can't work out how to adjust it? Regards Keith
![]() | #2 |
this is where i stand Join Date: Oct 2003 Location: Manchester
Posts: 13,581 Thanks: 289 Trader Rating: 0 ![]() | Re: hard to see speedo warning lights not adjustable, poor design. Easy way to fix it, sell the Sei and buy a Cinq ![]() welcome the forum btw ![]()
__________________ .:: 1368cc 16v Cinquecento ::. |
![]() | #3 |
![]() | Re: hard to see speedo warning lights Depends on the sei you have. I disagree its a problem or a design fault. The MPI idiot lights are dotted around the speedo and are fairly easy to see. There are some SPI speedos that have the idiot lights displayed at the top of the dash in a long line and some SPI speedos that have them that are at the side. I cant see it being a problem however, no ones mentioned it before Can you adjust the seat at all. Further back etc. Perhaps try and change your driving posistion? As mentioned the coloum is not adjustable. Also welcome ![]() ![]()
__________________ ![]() 2001 Modded Sei Sporting - GONE!! ![]() CLICK ME FOR A CENTO CHUCKLE - http://www.fiatforum.com/cinquecento...ease-help.html MY ACCIDENT THREAD - BE CAREFUL OUT THERE! - http://www.fiatforum.com/leisure-lou...cky-alive.html Last edited by AppleSei; 29-03-2006 at 00:16. |
![]() | #4 |
Posts: 13,581 Thanks: 289 Trader Rating: 0 ![]() | Re: hard to see speedo warning lights the outer edge of the steering wheel does a fine job of blocking all the lights from view, it was something i noticed driving Gexs mk1 Sei.
![]() | #5 |
![]() | Re: hard to see speedo warning lights TBH i have not been in a SPI sei with that kind of instrument light setup, obviosuly aware of that design, im gathering its the setup at the top with all lights in a line were discussing and is a problem?
__________________ ![]() 2001 Modded Sei Sporting - GONE!! ![]() CLICK ME FOR A CENTO CHUCKLE - http://www.fiatforum.com/cinquecento...ease-help.html MY ACCIDENT THREAD - BE CAREFUL OUT THERE! - http://www.fiatforum.com/leisure-lou...cky-alive.html |
![]() | #6 |
Posts: 13,581 Thanks: 289 Trader Rating: 0 ![]() | Re: hard to see speedo warning lights yeah, with the top of the speedo bit being curved - and the lights following that, you really can't see them as the steering wheel hides them all the way round!
![]() | #7 |
![]() | #8 |
Posts: 13,581 Thanks: 289 Trader Rating: 0 ![]() | Re: hard to see speedo warning lights they did, you said you've seen SPIs with different layouts..and the MPI doesnt have the same dash!
![]() | #9 |
![]() | Re: hard to see speedo warning lights doh! ![]() Never thought they didnt for that reason ![]()
![]() | #10 | ||
Posts: 6 Thanks: 0 Trader Rating: 0 | Re: hard to see speedo warning lights Hi Guys Thanks for all the replies but unfortunately there is no fix to my solution as my driving position is good, I'm worried about leaving my indicators on for miles before I realise, was thinking about installing a little LED on the dash in a inconspicuous place to warn me I have left the blinkers on. Any one know how to get to the Speedo bulbs as one of mine are out and needs replacing. please help ![]() Regards
![]() | #11 |
![]() | Re: hard to see speedo warning lights ![]() Hi Guys Thanks for all the replies but unfortunately there is no fix to my solution as my driving position is good, I'm worried about leaving my indicators on for miles before I realise
![]() | #12 | ||
Posts: 442 Thanks: 11 Trader Rating: 0 ![]() | Re: hard to see speedo warning lights Get yourself a pair of bucket seats and install them 5cm lower than the original potision. Worked fine for me... Or get an OMP or Simoniracing steering wheel, with an oval stem...
![]() | #13 |
![]() | Re: hard to see speedo warning lights Right just been out to look at my dash and it would seem its not much of an issue IMO, its easy to see the important lights, as you say headlights and indicators and also key code light are hard to see as they are round very top but indicators should turn off on their own (as mentioned already) and the other don't really matter - i mean you can't leave your lights on by accident in a fiat. down left side got oil, temp and battery lights and on right injector, airbag and power steering lights. I have absolutely no trouble seeing them, how tall are you? (i'm just under 6 foot)
__________________ Finn: Panda 100HP Oberyn: Suzuki Ignis Sport Urchin: Alfa 159 SW PEX: Cinq Track Car Some previous cars: Bravo HGT, Cinq 16v, Sei Turbo, Punto GT, Panda Mania 1242 mpi |
![]() | #14 | ||
Posts: 442 Thanks: 11 Trader Rating: 0 ![]() | Re: hard to see speedo warning lights I am 6'3". With the buckets lowered by about 2 inches, my oval steering wheel clears the indicators by an inch or so. With the original seats and steering wheel, had a little trouble with the top indicators like you.
![]() | #15 |
![]() | Re: hard to see speedo warning lights ![]() I am 6'3". With the buckets lowered by about 2 inches, my oval steering wheel clears the indicators by an inch or so. With the original seats and steering wheel, had a little trouble with the top indicators like you.
![]() | Paul C | Punto (Mk2/2b) | 40 | 05-06-2016 21:19 |
![]() | davycha | Ulysse | 2 | 08-07-2005 15:00 |
![]() | apierdomi | Stilo | 1 | 16-08-2004 23:09 |
![]() | JW | Stilo | 1 | 18-07-2004 15:56 |
![]() | peteu | Bravo / Brava | 11 | 20-04-2003 00:49 |
