Old 30-12-2003   #1
Hot start - no go!!
I have a 1997 cinque sporting, 35,000 on clock. It has developed a strange fault, can anyone help?
After a journey of more than 20 minutes if I return to the car after letting it start to cool down and then turn the key nothing happens. Not even a click. It doesn't appear to be the starter motor. The car will start with a jump or push. The car will also start from cold. Help!!
J9 is offline Reply With Quote Quote
Old 30-12-2003   #2
HP
I was only doing 80...
HP's Avatar
HP has donated!
Check the earth strap between gearbox and chassis.
Welcome to the forum too, fella.:)
Pete.
Cinq sporting 1242cc
Cinqs&Seis Yahoo group
Clubcento
HP is offline Reply With Quote Quote
Old 31-12-2003   #3
Thanks. Have checked looks ok. Cleaned up in that area. Will have to wait now and see what it does after a long journey. Have to have two wheel bearings replaced next week, feel the whole car is falling apart!!!!
Old 31-12-2003   #4
HP
HP's Avatar
HP has donated!
Would they be rear bearings? if so, usual cause is a sticky handbrake overheating them. If you fix the bearings and not the brakes they will fail again.
Pete.
Clubcento
Old 04-01-2004   #5
Drivers side wheel bearings front and back,husband said and garage have confirmed this. Car going to garage this week. The garage checked the strap for me when they had the car in last week and cleaned up around the battery etc and guess what, the bl***y thing wouldn't start from hot today after a journey of 5-10 minutes and a rest of half an hour. Luckily I was only at a friends house. Very unreliable.
Old 05-01-2004   #6
Became old and sensible
MrDerv's Avatar
MrDerv has donated!
Get a diagnostics check on the ecu from Fiat. It may be running on "Limp" mode.
There's a certain satisfaction you get from driving over a Sleeping Policeman
MrDerv is offline Reply With Quote Quote
(T) Seicento SX 2001 won't start dimension3 Cinquecento / Seicento 12 27-11-2008 08:45
(T) car wont start Joint_Jones Cinquecento / Seicento 3 12-06-2004 16:34
(T) Tipo doesn't start after idle feil Tipo (Classic) 4 28-04-2004 18:35
(T) Cold Start spray fixed it . How ? Oilslick Punto (Mk1) 5 02-12-2003 03:05
(T) 83 SPIDER WON'T START TEXASTOUGHFIAT 124 Spider (Classic) 2 20-06-2003 04:14
