| Thread Tools |
![]() | #1 | ||
Posts: 132 Thanks: 0 Trader Rating: 0 ![]() | Oil / Water leak - headgasket ? Please look ![]() ![]() Car doesn't misfire, no flat spots. But I always seem to have an oil film at the arrowed parts. I also noticed that the Coolant level dropped from max to below min within a week. However there is no sign of a leakage on my driveway... I have receipts that the waterpump has been changed about 8 months ago, radiater has been changed 1 month ago. Any Ideas ??
![]() | #2 | ||
Posts: 231 Thanks: 0 Trader Rating: 0 ![]() | Re: Oil / Water leak - headgasket ? Please look Top picture looks like ur rocker cover gasket has gone mate. mine did the same thing , i have changed it now and its fine ![]()
![]() | #3 |
this is where i stand Join Date: Oct 2003 Location: Manchester
Posts: 13,581 Thanks: 289 Trader Rating: 0 ![]() | Re: Oil / Water leak - headgasket ? Please look yeah, that is just a cam cover gasket leak. take it off (4 bolts) clean the gasket surfaces very very well and bung a new gasket in.
__________________ .:: 1368cc 16v Cinquecento ::. |
![]() | #4 | ||
Posts: 132 Thanks: 0 Trader Rating: 0 ![]() | Re: Oil / Water leak - headgasket ? Please look That was quick! Thanks. Would this explain the water loss aswell ?
![]() | #5 |
Posts: 13,581 Thanks: 289 Trader Rating: 0 ![]() | Re: Oil / Water leak - headgasket ? Please look no does it keep loosing water, or has it just dropped the once? It could have just been an air lock. dont worry unless it keeps using water.
![]() | #6 | ||
Posts: 132 Thanks: 0 Trader Rating: 0 ![]() | Re: Oil / Water leak - headgasket ? Please look it was just the one time so far... just another dumb question: Can I clean it with WD40 ? Or what do I need to use ![]()
![]() | #7 |
Posts: 13,581 Thanks: 289 Trader Rating: 0 ![]() | Re: Oil / Water leak - headgasket ? Please look i'd use degreaser. specifically Gunk ![]()
![]() | #8 | ||
Posts: 132 Thanks: 0 Trader Rating: 0 ![]() | Re: Oil / Water leak - headgasket ? Please look I checked again today and the water keeps boiling over. checked oil level - fine. There is no trace of oil in the coolant tank. anycideas what it might be ?
![]() | #9 |
Posts: 13,581 Thanks: 289 Trader Rating: 0 ![]() | Re: Oil / Water leak - headgasket ? Please look faulty expansion tank cap
![]() | #10 | ||
Posts: 132 Thanks: 0 Trader Rating: 0 ![]() | Re: Oil / Water leak - headgasket ? Please look I really hope that is just a faulty cap. I will replace the cap & rocker gasket tomorrow
![]() | #11 |
Posts: 23,467 Thanks: 1147 Blog Entries: 3 Trader Rating: 1 ![]() | Re: Oil / Water leak - headgasket ? Please look Check that the cooling fan is operating. Cheers D
__________________ |
![]() | #12 | ||
Posts: 132 Thanks: 0 Trader Rating: 0 ![]() | Re: Oil / Water leak - headgasket ? Please look cooling fan is working fine. temperature light didn't come on so far...
![]() | #13 |
Posts: 23,467 Thanks: 1147 Blog Entries: 3 Trader Rating: 1 ![]() | Re: Oil / Water leak - headgasket ? Please look Make sure the fan is running at full speed, the bearings begin to drag causing the fan to move enough air. Cheers D
![]() | #14 |
Posts: 13,581 Thanks: 289 Trader Rating: 0 ![]() | Re: Oil / Water leak - headgasket ? Please look i still think its the cap failed, system not pressurising and so boiling early.
![]() | #15 | ||
Posts: 132 Thanks: 0 Trader Rating: 0 ![]() | Re: Oil / Water leak - headgasket ? Please look Fitted a new cap. & the new gasket. Took it for a short 10 mile run - no oil leak, no overboiling coolant. i didn't even know those caps can go wrong ![]() ![]() Thanks four your great advise.
Thread Tools | |
![]() | Gman | Cinquecento / Seicento | 17 | 08-02-2006 09:55 |
![]() | Hallsy200sx | Cinquecento / Seicento | 18 | 23-01-2006 16:08 |
![]() | Jayjj | Bravo / Brava | 11 | 03-04-2005 19:03 |
![]() | martin.butler | Punto (Mk2/2b) | 2 | 20-02-2005 21:08 |
![]() | andy dowds | Panda (Classic) | 9 | 30-08-2004 09:54 |
