Not sure why the car has started doing this. It keeps blowing the 20A fuse in the engine bay. Yellow fuse holder near the ECU. It is the fuel pump fuse.
Everytime it blows, i get out and fit a new one and it fires up again.
There seems to be no pattern to it. Doesnt happen on bumps, doesnt happen when cornering fast, or sharp. It hasnt done it when cold yet though.
I suspected my ICE grounding near the fuel pump might be the problem - so i moved that to one of the seat mounts and it made no difference.
It does it with ICE on or off anyway.
I recently swapped out the rear gearbox mount, is it possible ive trapped a cable somewhere doing that? Ive tried wobbling the running engine - but that doesnt cause it to blow.
It was suggested i check the reverse light switch wiring. I did, it was damaged. I unplugged it. It blew the fuse later that day. I repaired the wire with some tape and plugged it back. It's blown the fuse again since. Somewhere in that lot it blew the reversing light bulb.
No wiring fault with the reverse light now though.
I'm running out of ideas. Where does the wire for the fuel pump run from and too - help!
