Hi All
Trying to replace the inner gaiter on my wifes 899 sei and i cant get the new bearing onto the shaft. I have tried a piece of plastic tbing and whacking it with a lump hammer but no luck. Any ideas on what would be better to whack the bearing on?
Also, i loosened the nut on the track rod end ball joint and used a seperator to split the joint. But when i came to trying to undo the bolt it spins the whole nut. So i cant undo or do up this bolt. Any ideas???
Thanks in advance
Cy
Thanks in advance
Cy
