Hi guys.
I have just read this exhaustive tyre/rim bible page
http://www.carbibles.com/tyre_bible.html
and have gained some knowledge about tyre/rim sizing and compatibility.
But, to be more sure in my choice, I want to ask for the advice of those of you who are aces in tyre/rim adjustments.
I have to change rims on my non-sporting Cinq (as the old ones are all bent and noone could give them the usual round shape, which would be very helpful for the overall car shaking problem).
According to the following web-site
http://atschool.eduweb.co.uk/ajwebster/tune7.html
"if you are fitting wider wheels to a standard non-sporting Cinquecento a lowering kit must be added as part of the upgrade, this is a Fiat recommendation and will avoid any sharp-cornering (elk test) induced rollover problems similar to those suffered by early Mercedes A-class cars."
It also states that
"The manufacturers standard fitment is :
Tyre 165/55X13 Wheel 5.5X13 Offset 29mm "
My Cinq currently has tyres of 145/70x13 Wheel 4.0x13, unknown offset (probably 29mm??).
What i would like to do is to fit my current tyres (145/70x13) on 5.5x13 offset 29mm wheels, which seems to be allowed by using the calculator on the
web-site (search for "An ideal rim-width calculator" on the page).
The question is: is the Tyre 165/55X13 Wheel 5.5X13 Offset 29mm really the standard fitment (as stated on the web-site mentioned above)?
If it is, then I guess my choice of fitting 5.5x13 wheels would be "standard" (not too wide) and would be approved without adding a lowering kit and nothing unexpected would happen by just changing the rims.
Your help is greatly appreciated.
It also states that
