| Thread Tools |
![]() | #1 | ||
Posts: 1,091 Thanks: 34 Trader Rating: 0 ![]() | Punto 75 engine. I have found one for sale, they seem to be quite rare. I guess no-one wanted to pay extra when they were new and and now everyone want the big valve head and hotter cam for their engine conversions. Its meant to be in good condition and have a genuine 61000 miles out of a 1996 car. What kind of price should I be paying? Also what do you recommend doing to the engine before fitting it? new rings, head skim, etc.... .
![]() | #3 |
Posts: 9,865 Thanks: 116 Trader Rating: 0 ![]() | Re: Punto 75 engine. The 75 doesn't have bigger valves, but does have a higher lift cam and a higher compression ratio (9.8 vs. 9.6).
__________________ Pete. "Make something idiot proof and someone will just go and build a better idiot". |
![]() | #4 |
this is where i stand Join Date: Oct 2003 Location: Manchester
Posts: 13,581 Thanks: 289 Trader Rating: 0 ![]() | Re: Punto 75 engine.
__________________ .:: 1368cc 16v Cinquecento ::. |
![]() | #5 |
Posts: 9,865 Thanks: 116 Trader Rating: 0 ![]() | Re: Punto 75 engine. It's got the same size valves as an 1108 cento. Article is temporarily withdrawn for editing.
![]() | #6 | ||
Posts: 447 Thanks: 0 Trader Rating: 2 ![]() | Re: Punto 75 engine. i was about to open a new thread but seen as iv seen this theres no need, iv been offered a pun to 75 for £100 its had a rear end smash so just want it for the engine the engine in it has done 110k but does run mint although im not too sure as its a lot of miles for a small engine what else do i need to fit this? i understand i need a uncoded ecu or a remapped chip in my ecu can the punto 4-2-1 exhaust be used? cheers
![]() | #7 | ||
Posts: 1,091 Thanks: 34 Trader Rating: 0 ![]() | Re: Punto 75 engine. Sorry, dont know where i got the idea the valves were bigger. Basically anything under £100 would be a good deal, even if I only got the cam out of it. Thanks.
![]() | #8 | ||
Principality Retained :) ![]() | Re: Punto 75 engine. ![]() i was about to open a new thread but seen as iv seen this theres no need, iv been offered a pun to 75 for £100 its had a rear end smash so just want it for the engine the engine in it has done 110k but does run mint although im not too sure as its a lot of miles for a small engine what else do i need to fit this? i understand i need a uncoded ecu or a remapped chip in my ecu can the punto 4-2-1 exhaust be used? cheers You need a miracle to rewire the cento loom to take that ECU into account Id think. It uses the driveline from the Cinq otherwise. In worst acse you could use the bottom end with the Cinq head (the bottom end is slightly stronger than the 1108 I believe) and have a 1242 SPi!
![]() | #9 | ||
Posts: 447 Thanks: 0 Trader Rating: 2 ![]() | Re: Punto 75 engine. there was someone on here who said thye might be able to do a chip for the standard ecu which had the mpi map and wire the standard injector wires into 4. i also thought the valves were bigger so after finding this out i may just get a 1242 spi with tricker tb and punto 75 cam as this shouldnt be far off the power of a 1242mpi doubt ill bother with that punto then as 110k miles is quite a lot so the bottom end wont be too good but the cam should still be ok shouldnt it so i might just get that cheers
![]() | #10 | ||
Banned Join Date: May 2005 Location: On da way 2 a new mission
Posts: 3,615 Thanks: 69 Trader Rating: 0 ![]() | Re: Punto 75 engine. ![]() It's got the same size valves as an 1108 cento. Article is temporarily withdrawn for editing.
![]() | #11 |
Posts: 9,865 Thanks: 116 Trader Rating: 0 ![]() | Re: Punto 75 engine. ...but they're the same part number as 1108 SPI Centos.
![]() | #12 | ||
Posts: 1,091 Thanks: 34 Trader Rating: 0 ![]() | Re: Punto 75 engine. This is getting worse!! I may go and hassle the parts department in the local fiat dealer to find this out. Although I am sure they wont want to fiddle about.
![]() | #13 | ||
Posts: 517 Thanks: 7 Trader Rating: -2 ![]() | Re: Punto 75 engine. https://www.fiatforum.com/cinquecento-seicento/52666-its-last.html This is what I made from a 1108 '55' and a 1242 '75' combo, works well and has loads more torque. This is a mpi bottom end but I used half of the 75 throttle body as its 38mm which is quite a lot bigger than the standard cinq one. If you need any help let me know as I have done quite a few of these engines and work on quite a few cinqs in the area. I honed out the block also as they had suffered from bore wash and I was unsure of the milage. Cheers Rich.
![]() | #14 | ||
Posts: 442 Thanks: 11 Trader Rating: 0 ![]() | Re: Punto 75 engine. ![]() there was someone on here who said thye might be able to do a chip for the standard ecu which had the mpi map and wire the standard injector wires into 4. i also thought the valves were bigger so after finding this out i may just get a 1242 spi with tricker tb and punto 75 cam as this shouldnt be far off the power of a 1242mpi doubt ill bother with that punto then as 110k miles is quite a lot so the bottom end wont be too good but the cam should still be ok shouldnt it so i might just get that cheers PS. I believe the 1242 mpi head also has wider intake ports and a different intake manifold bolt pattern, so it's not only cam and TB. Also the mpi uses a thinner head gasket which raises the compression ratio from 9.6:1 to 9.8:1, but that's easy to achieve if you use the mpi gasket (or even the new metallic gasket used at the 95Hp fire, that gives a 10.6-10.8:1 or so ratio...). Check it out... Also, as it injects fuel right on the valve, forget the cold starting flat spots of the spi injection...
![]() | #15 |
Thread Tools | |
![]() | crizz | Punto (Mk2/2b) | 5 | 22-05-2005 17:30 |
HGT punto engine | ChrisHGT | Auction Watch | 1 | 08-05-2005 12:08 |
![]() | sniffer | Cinquecento / Seicento | 10 | 04-04-2005 12:37 |
Max HP from Punto 60 Engine | TurboCinqy1250 | Lets Talk FIAT | 17 | 20-03-2005 23:27 |
![]() | HP | Cinquecento / Seicento | 0 | 31-12-2004 01:17 |
