Hallsy200sx
- Feb 10, 2005
- 56
- 17
Right, you may remember a while back that I posted on here about my gf's sei loosing coolant rapidly. Guessed at water pump as that was vacinity of leak.
Have now got bits (pump & cambelt) and have got all covers off, etc and with the aid of a torch have realised that the water pump isn't leaking, it is in fact leaking from a hole in the block above the oil filter (hole is about 5mm dia.).
If I fill the expansion bottle it literally pisses out of here!! Is this a core plug? If it is, why is it leaking and how can I stop it? Plumbers mate??
I'll still replace the pump & cambelt as it's done about 50k so cambelt needs doing and may as well do the pump as I've got one.
Just need to sort this leak!!
