Technical Seicento Sportin Temperature?
dawozere
Member
Manchester, United Kingdom.
Hey Peeps,
I have a seicento sporting, and it doesn't have a temperature guage on it. Do you know how it tells u that the temp is ok or too high?
is there any easy way of fitting a temp gauge?
cheers
Seicento Sportin... Maybe i'll get it off the drive... one day... maybe
i was under the impression that it was only base model cinqs that lacked a temperature gauage - i thought the same would be true with the sei.. so a sporting should have one.
Is there not a light that lights when you are overheating? check your dash for any bits that light that you've never seen on!
Cinq Sporting - and yes, its broom yellow!
There's an overheating warning light, no Seis have a temp gauge fitted as standard. All you have to do on an SPI sei is buy a gauge and fit it, putting the sender in place of the standard switch. If you have the MPI one, the tapping is blanked off on the head - not sure if it's plugged or hasn't been drilled though.
If you buy a gauge, I'd recommend electric ones over mechanical capiliary gauges any day.
Pete.
Cinq sporting 1242cc
Cinqs&Seis Yahoo group
Clubcento
Cheers fixit, is the bit i need to replace on the radiator where the switch is for the fan? or am i thinkin of the wrong bit? mine is the SPI engined sportin
does anyone know a decent cheap place to get hold of a decent lookin temp gauge?
cheers
wrong bit. its down near the battery, sticking out the side of the engine.. a pic would be handy.. but i dont have one - do you have a haynes manual?
ive just fitted a temp guage 2my sei sporting (it came with a pod and ive put it next 2 the rev counter), wired it up just need get a adptor for the sendor, i got a website (http://www.lemansmotorsport.co.uk/motorsport/Products/Gauge_Fitting_Parts/gauge_fitting_parts.html) for diff adaptors but dont know what size i need:(
