Technical brake lights stay on constantly - help!!!
shuggyboy24
United Kingdom.
hi folks
On my cinq when i put my lights on the brake lights are constantly left on without even touching them anyone had this prob or got any ideas what is causing it?
thanks
shuggy
hi guys
tried the fuse box alls ok whats the switch that you mentioned fixitagaintomorrow is it easy to locate and then adjust?
thanks
shuggy
Wish my brake lights came on at all... anyone know where to check first?
Matt
Crystal CMP 8 :: Like some members on this forum, thinks its 4 inches bigger than it is
anything like brake and reversing lights its just a process of elimination.usually after checking fuses and bulbs you just have to backtrack.if youve got a multitester check for power on circiuts back to the fusebox,if youve no tester i usually rig up a courtest light with wires to check for power.for the reversing lights id check the connections on the switch if there ok id replace the switch cos there not that expensive[8D]
The Fiat Cinquecento
Fun While It Runs
yay! Brake lights are working, its inly taken me about 2 months to sort out! It was one of those things I really couldnt be arsed doing, only needed a pair of bulbs, a couple of quid.
Motoring is now a pleasure again...no fear of being rear ended by my lack of lights! :D
Matt
