rob88
I hope someone can help me with this problem, The car is a 1999 Seicento, the problem is as follows; when the headlights are turned on the right indicator comes on(doesn't blink) and the right headlight also dims a bit. When the right indicator is switched on the only thing that happens is the two dash lights either side of the headlight indicator light up slightly. The left indicator works fine. The right indicator works fine when the headlights are off.
Any help on this matter would be much appreciated.
