Old 02-12-2003   #1
Footwell Lighting
Right, the plan is to run 2 red leds tubes, hidden away under the dash in each front footwell. I want to rig it up on the same system as the interior light runs on, so when the doors open, you get a nice red glow at night.
The LED tubes themselves are PC tubes, meaning its a molex connector, but i'm assuming i can just butcher that down to a red and black wire. Is it a simple case of joining it up to the interior light, or will running 2 lights from this simply dim all 3 lights? And would i have to change the fuse so to compensate for the extra power being used by the light?
Obviously, just sticking the wires straight on the battery and rigged up with a switch would be the easist route, but then i want it to light up as the doors open. Any suggestions?
mckrob is offline Reply With Quote Quote
Old 02-12-2003   #2
Not too electronically minded but a relay? So that when the doors open the relay swithches on and the lights (wired fom the battery) switch on? That wouldnt dim any lights I think.
Just remeber fuses so you dont return to a smoldering wreck.
Matt
Crystal CMP 8 :: Like some members on this forum, thinks its 4 inches bigger than it is
Sando is offline Reply With Quote Quote
Old 03-12-2003   #3
Possibly! I'm gonna rip off the interior light tomorow and have a poke about.
Old 03-12-2003   #4
Became old and sensible
MrDerv's Avatar
MrDerv has donated!
it won't dim them at all. If these lights are supposed to be for the inside of a PC case, They'll be fine without a relay as they won't draw much current from the electrics, that is unless the tubes need a transformer to run them in which case, put in a relay:)
Speedbumps are my arch enemys!!!
MrDerv is offline Reply With Quote Quote
Old 03-12-2003   #5
Its just an LED tube with a molex connector, which i WILL butcher down to positive and negative wires. I'm just about to go outside and have a look underneath the light cover and see whats what.
Old 03-12-2003   #6
I had a spare blue neon from an old sub box I sabotaged and that had the neon and then a transformer, it was basically just a negative and positive wire. Simple stuff.
Get a positive and negative and hook it up just to check before butchering it though....probably too latenow anyway! :D
Matt
Old 03-12-2003   #7
I had a look at the interior light, no wires visible in the light itself, so i'm guessing the wires run into the roof and down the A-pillar.
But before i do anything i'll check some wiring diagrams in the Haynes manual.
Old 04-12-2003   #8
arc
this is where i stand
arc has donated!
LED tubes? I've never seen one of these.. do you mean a cold cathode tube?
Have you bought one yet, a cathode is likely to be brighter than a LED tube.
http://www.ebuyer.com/customer/products/index.html?action=c2hvd19wcm9kdWN0X292ZXJ2aWV3&pro duct_uid=42955
And at only £2.50 - they're a steal. They run off an invertor that is supplied but only draw a few mere mA so no need for a relay.
I have two white ones for my footwells, just not got round to fitting them yet!
Cinq Sporting - and yes, its broom yellow!
arc is offline Reply With Quote Quote
Old 04-12-2003   #9
Principality Retained :)
Trader Rating: 3
arseofbox has donated!
Fook...I had two of those slung under each bumper until august when they fell off. Arc youre right..they ARE a steal, mine cost £10 each when I did mine in April. I might just do the internal thing myself.
Those are an absolute piece of (you get the picture) to fit. I had mine wired directly to the battery....:D
Arse
Ill think of something witty....just wait and see............wait I might not.
arseofbox is offline Reply With Quote Quote
Old 04-12-2003   #10
I fancy a bit of this lighting myself, if anyone manages to find out how to hack into the power cablin for the internal light give us a shout.
Does anyone know how many tubes we could feasibly run? i was hopin for 6 for the idea i've got in mind?
cheers
dave
Seicento Sportin... Maybe i'll get it off the drive... one day... maybe
dawozere is offline Reply With Quote Quote
Old 04-12-2003   #11
well, if you all getting one, i might finally tidy up my boot install and put one or two in there! :p
think that would look right smart! [8D]
mackett is offline Reply With Quote Quote
Old 04-12-2003   #12
Funnly enough, the ones i'm getting are from ebuyer. Not the cold cathode tubes though, as they use inverters, so its more wires, plus the red one has been reported as looking orange.
I was thinking of two of these: http://www.ebuyer.com/customer/products/index.html?action=c2hvd19wcm9kdWN0X292ZXJ2aWV3&pro duct_uid=44986
Old 04-12-2003   #13
im looking for two blue cold cathodes. about 12 inches. then i could have one behind my amp, and one behind the sub. think that would look nice. but, ebuyer didnt have a normal blue one, just this:
Liquid Neon Tube 12 Inch Blue
Old 04-12-2003   #14
Trader Rating: 3
When I was running those below my bumpers..I was using Cold Cathodes. Just cut the two wires from the PC connector, and cram the wiring for the inverter somewhere. It cant be that hard..theres a load of room behind the fascia!
As for the colour. I had red ones outside before they fell off:D. It is red, not orange. But it is fairly pale and nearly pink!!
Arse
Old 04-12-2003   #15
ewww, pink! I think i'll go with the LEDs over the cathodes. So now its established what to get, but any ideas on running it in the same way as the interior light? I'm guessing find the 2 wires that run to the interior light, and join the new ones onto that circuit...
(T) Water ingress to driver's footwell, Punto meirion Punto (Mk2/2b) 5 19-05-2004 05:18
(G) Uno - water in the footwell Steven Uno 18 06-04-2004 04:57
(G) Water ingress to driver's footwell meirion Punto (Mk2/2b) 3 15-03-2004 05:55
(T) Water leak into drivers footwell edmoff Punto (Mk2/2b) 8 26-01-2004 22:32
(G) Lighting Ron le Taxi Ulysse 3 11-12-2003 02:42
