A arc this is where i stand Parked in the garage Joined Oct 8, 2003 Messages 19,719 Points 3,335 Location Manchester Dec 22, 2005 #1 Anyone know what the cam bearing caps should torqued to? Haynes has given me 2 values to pick from, one being double the other - i'm tempted to go for 10Nm - that *sounds* correct to me. But i wanna be sure
dave ****** Parked in the garage Written 10+ guides Joined Aug 10, 2003 Messages 125,246 Points 24,395 Location Essex/Suffolk border Dec 22, 2005 #2 is it not 1 setting for the 13mm (head) bolts and the lesser one for the 2 10mm (head) bolts at the coils end?
OP OP A arc this is where i stand Parked in the garage Joined Oct 8, 2003 Messages 19,719 Points 3,335 Location Manchester Dec 22, 2005 #3 all the bolts are the same
dave ****** Parked in the garage Written 10+ guides Joined Aug 10, 2003 Messages 125,246 Points 24,395 Location Essex/Suffolk border Dec 22, 2005 #4 the last one has 4 bolts am sure 2 of each
HP I was only doing 80... Parked in the garage Written a guide Joined Mar 22, 2002 Messages 13,429 Points 2,034 Location North East Dec 22, 2005 #5 Dave's right, the long bolts are higher torque and the 2 shorter ones on the coil end cap are the lower.
GeX Established member Joined Jan 12, 2004 Messages 529 Points 182 Location Lytham St.Annes Dec 22, 2005 #6 arc posting here: I've just taken the 1108 to bits, and see what you mean about the 4 bolts. so theres 2 near timing end, 2 in the middle, 2 at the coil that are under the cam cover, and then 2 that are not. So they're all the higher torque (17Nm i think) and the others that are outside the cam cover are 10Nm ?
dave ****** Parked in the garage Written 10+ guides Joined Aug 10, 2003 Messages 125,246 Points 24,395 Location Essex/Suffolk border Dec 22, 2005 #7 yep but i no use a torque wrench on them, i do tight and a bit
A arseofbox Principality Retained :) Joined Jul 16, 2003 Messages 6,978 Points 1,063 Location Midlands Dec 22, 2005 #8 I thought they were 35NM!!! Whoops. My bad
dave ****** Parked in the garage Written 10+ guides Joined Aug 10, 2003 Messages 125,246 Points 24,395 Location Essex/Suffolk border Dec 22, 2005 #9 arseofbox said: I thought they were 35NM!!! Whoops. My bad Click to expand... i dunno if the nm is right but it be the tighter one for the bigger bolts innit
OP OP A arc this is where i stand Parked in the garage Joined Oct 8, 2003 Messages 19,719 Points 3,335 Location Manchester Dec 23, 2005 #10 35 sounds way much
O Oldschool Banned Joined May 10, 2005 Messages 3,739 Points 523 Location On da way 2 a new mission Dec 23, 2005 #11 20Nm for the six cam cap bolts. 10Nm for the two coil bracket seal screws.
