FIAT Auto Specialist Team
Old 20-12-2005   #1
Disc change
Hi Folks,
Changed the discs\pads on my 2001 Sei Sporting yesterday....The wheelstuds were INCREDIBLY tight ! Took me around 15mins each to extract....Is this normal???
They were just as tight on the way back in even greased up with copperslip. There is no thread damage and they aint rusty.
I changed the disc 'cause one of them was scored and squeeling, yet the calipers are moving (sliding) freely and the piston moves in and out the bore with no problem.
Using the car today, I thought I heard a squeek at one point !! But I may have imagined it.....
One other thing...In the mornings when I press the brake, its like the pedal is sticky...only for the first press, after that all is normal.
Any comments??
Gerry
48POP is offline Reply With Quote Quote
Old 20-12-2005   #2
Funny saying here
jamie86's Avatar
Trader Rating: 1
jamie86 has donated!
Re: Disc change
Did you change the brake fluid as well?
The scoring could of been something as silly as a stone getting caught..
Quote Originally Posted by A wise person
Mini invented the giant killer, VW started the genre, Ford & Vauxhall Desecrated it, but the Peugeot 205 GTi was undoubtedly the king of the breed.
jamie86 is offline Reply With Quote Quote
Old 20-12-2005   #3
Re: Disc change
The wheelstuds, yeah they are very tough to take off the first time you come to do it. I seem to recall a complex series of levers was required.
I think a squeak can be caused by not having greased the back of the brake pad(where it mounts onto the caliper). People will correct me on this.
AS for the pedal stickyness, my brake pedal does the same first thing on a cold morning too. Dunno if its a good or bad thing but i don't worry too much about it. I just press the brake before i get to the end of the drive and it alrighty.
GeX is offline Reply With Quote Quote
Old 20-12-2005   #4
Re: Disc change
All I can say is I hope the wheel studs never need to come off again !!!
I lightly greased up all of contact points and the back of the pad so hopefully the pads are moving freely.....
Is there a recommended "bedding in " process, or should I just drive gently for a few hundred miles...
Gerry
Old 20-12-2005   #5
hi friends :waves:
Liam's Avatar
Liam has donated!
Re: Disc change
Sounds like the wheels have never been off in it's life, erm try not to hammer the brakes and drive gently for 150-200 miles then brakes as normal.
Liam
Yes it's really me!
97 Cinq Sporting-RIP 09/10/06 BYE OLD FRIEND
Liam is offline Reply With Quote Quote
Old 20-12-2005   #6
Autotest Special
rallycinq's Avatar
Trader Rating: 1
rallycinq has donated!
Re: Disc change
I beg to differ, but your wheel bolts have been stretched by overtightening. They may look alright, but they should come off with your fingers once the first pressure has been released.
Replace your bolts immediately, before they snap, and tighten to the proper torque.
David
Old 20-12-2005   #7
Re: Disc change
Hmmm, that does not sound good. They came loose as you suggested but after about a 1\4 turn, they were tight all of the way out...Nearly gave me a hernia !!
What thread are they, cause I doubt if I could manage to shift them again with a 19mm spanner. If I could lock up a couple of nuts on the stud, I could get a socket on and wind it out with a breaker bar.....
All advice welcome
Gerry
(also in Scotland....)
Old 20-12-2005   #8
Status: DEFCON Grumpy
custard's Avatar
Trader Rating: 1
custard has donated!
Re: Disc change
Quote Originally Posted by 48POP
All advice welcome
Gerry
go the jocks
Old 20-12-2005   #9
Autotest Special
rallycinq's Avatar
Trader Rating: 1
Re: Disc change
Apologies, I think the sei has studs with nuts on. The studs will have been put in with threadlock which is why they would be difficult to come out. You should have run a tap or thread cleaner down the holes and refitted with fresh threadlock.
Cheers, or eh hoots
D
Old 21-12-2005   #10
Slippy has donated!
Re: Disc change
Quote Originally Posted by rallycinq
Cheers, or eh hoots
D
No - they Sei has Bolts. Studless hubs.
I think you were right in the first intance rallycinq. Stretched Bolts.
Had to buy a new set the other day for mine. Order them through your local garage - mine came to 1.74 + VAT for a set of 4!!!
http://www.fiatforum.com/gallery/dat...new-sig-an.gif
Quote Originally Posted by Steve
You choose well. The red Sei is gorgeous, probably the nicest Sei on the forum.
Quote Originally Posted by mekinhos
That's the nicest Seicento I've ever seen
Amazing
Slippy is offline Reply With Quote Quote
Old 21-12-2005   #11
Principality Retained :)
Trader Rating: 3
arseofbox has donated!
Re: Disc change
Quote Originally Posted by Slippy
Theres both I think.
I would think that they are non-tensile bolts myself (not designed to stretch)...so replace them ASAP...youre meant to do that with stretch bolts anyway...
arseofbox is offline Reply With Quote Quote
Old 21-12-2005   #12
Re: Disc change
Well i know my Sei has studs and nuts. I couldn't be doin with the Cinq studless design, makes it more of a faff trying to get the wheel back on.
Old 21-12-2005   #13
Autotest Special
rallycinq's Avatar
Trader Rating: 1
Re: Disc change
Cos I is a smartarse my cinq has studs and nuts. The OP mentions that he would need to put two nuts on to get the studs out so I was going on the basis that this Sei was a 'stud 'n' nut' one.
D
(T) Rear disc and pad change - 20v. :o/ HP Marea 9 13-07-2005 21:40
(T) Rear disc pads. cmk12342000 Stilo 3 21-10-2004 07:41
(G) Is it ok to do an oil change? 128v Punto (Mk2/2b) 3 17-08-2004 21:35
(T) Back brake to be changed early imply disc damaged siecle21 Stilo 5 13-11-2003 20:07
