Thread Tools
Old 19-12-2005   #1
Exclamation my wifes chinq is doomed to scrap !
well here we go again ive spent the best part of six months rebuilding the car !
the story so far :
bought the car and was fine and all of a sudden it started to run like a bag of shi* and thought it could be the battery being crap.
changed it and still no change so then we went through all the possibilities
new plugs
new coil packs
new leads
new crank sensor
new map sensor
new (chipped) ECU
recon full head with gaskets
new earth strap
new injector
hhhhhhhhheeeeeeeeeeeellllllllllllllllppppppppppppp pppp comes to mind .......
please try and shine sum light on this for me :
basically what happens is when yu apply any pressure to the accelarator it splutters and stalls and it wont even idle properly .....
cheers shaun
shaunmurray is offline Reply With Quote Quote
Old 19-12-2005   #2
Forum Moderator
T14086's Avatar
T14086 has donated!
Re: my wifes chinq is doomed to scrap !
Often a dealer is the cheapest option!
Dont suppose you have had any codes read yet?
Old 19-12-2005   #3
Status: DEFCON Grumpy
custard's Avatar
Trader Rating: 1
custard has donated!
notice you havent tried a lambda sensor
Old 19-12-2005   #4
Forum Moderator
T14086's Avatar
T14086 has donated!
Quote Originally Posted by custard boy
DOH!
Old 19-12-2005   #5
Banned
Oldschool has donated!
Throttle position sensor and loom are two more possibilities.
Oldschool is offline Reply With Quote Quote
Old 19-12-2005   #6
Cinqs & Chester Jets rock
Jetsfan5 has donated!
Glops Melee Champion
Lambda sensor tends to give off a bad egg smell, so it might give you an indication. Recently replaced my lambda, cost 60 for the part - car was kangarooing badly and spluttering, it sounded like Chitty Chitty Bang Bang from the back.
Jetsfan5 is offline Reply With Quote Quote
Old 19-12-2005   #7
Talking Re: my wifes chinq is doomed to scrap !
tried FIAT but the car has been modified so they wont touch it ?????? and theres no light on my dash so im baffled !!!!! a mechanic ruled out the lambda in the first test he did !
shaun
Old 19-12-2005   #8
Forum Moderator
T14086's Avatar
T14086 has donated!
Cat gives off the smell not the lambda.
Light not on but code will still be logged for 64 cycles.
Old 20-12-2005   #9
lambda sensor
I didnt get any lights on the dash but had the same problems as yours .
They arent that expensive 50 ish and are very easy to fit so id give it a go , only use the correct model not one of those universal ones.
Curtis is offline Reply With Quote Quote
Old 20-12-2005   #10
cinqsandminis has donated!
Ireland
Fuel starvation (caused by crud in the tank blocking the coke-can sized filter under the middle of the car) can sometimes cause poor running - can the car be revved/driven? If it runs at low revs and stalls at high revs/under load I'd look at the filter.
(Oh BTW, I have an old lambda sensor - some muppet at the breakers cut the multiplug off but its in a jiffy bag and you can have it for £10 + £3 postage)
Sig cancelled due to lack of interest...
cinqsandminis is offline Reply With Quote Quote
Old 21-12-2005   #11
thanks for all the comments
the car wont drive at all and i aint got the time over xmas im busy building a harley bike for our son so it will have to wait till new year ..
shaun
Thread Tools
I am doomed to die in a car i tell u, DOOMED! Luciel Leisure Lounge 16 17-10-2005 19:42
