im Axle Specialists
Thread Tools
Old 23-11-2003   #1
noisy gear selection
Can anyone help. I got a sei sporting 2001 model and I got a problem with fourth gear. Whenever I change from 5th to 4th as I let the clutch up I hear a squeal from the gearbox/clutch area. I dont think the noise is in any other gear but I dunno what it can be.
ger is offline Reply With Quote Quote
Old 24-11-2003   #2
HP
I was only doing 80...
HP's Avatar
HP has donated!
Is it still under warranty? If so, take it back and get Fiat to have a look at it - sounds like it might be a gearbox or clutch problem (sorry to state the bleeding obvious!)
Pete.
Cinq sporting 1242cc
Cinqs&Seis Yahoo group
Clubcento
HP is offline Reply With Quote Quote
Old 11-07-2005   #3
Shepherd has donated!
Re: noisy gear selection
The squeal sounds to me like a dry clutch thrust bearing. I had a rover 600 before my Multipla and the thrust bearing squealed on occasions for about 25,000mls and still squealed when I traided it in.
Shepherd is offline Reply With Quote Quote
Old 11-07-2005   #4
Does the clutch cable still need manual adjusting on these cars, it could be causing a slight selection problem on that gear if not correctly adjusted..
Also would the gearbox being low on oil also cause a noise, because 5 th gear is high up on the end of the box and would get the least oil..
Paul T
paul_treg is offline Reply With Quote Quote
Old 11-07-2005   #5
If the box was low on oil there would be a constant whinning noise when driving, i know this because my Cinq hasnt got any oil in the box as the seal has gone and the car whines in all gears
crayon is offline Reply With Quote Quote
Thread Tools
(T) Another Clutch / gear box issue Zimon Cinquecento / Seicento 15 03-07-2005 14:55
(S) Shortening My Punto Gear Stick Abul Punto (Mk2/2b) 12 06-05-2004 08:16
(S) Gear Knob Replacement polecat Marea 0 15-02-2004 23:09
(T) Gear Selection Problems scrappydog Bravo / Brava 1 16-07-2003 15:54
(S) Gear Knob Pete600 Cinquecento / Seicento 10 08-05-2003 06:33
