FIAT Auto Specialist Team
Old 4 Weeks Ago   #1
Clunk feeling from the front as I pull away?
Doesn't do it every time which is a pain. Tends to be if I load everything up when I pull away, but again, not every time.
It just feels like something is shifting a bit as I move off.
I have replaced the entire front and rear suspension Over the summer. I asked the MOT tester to see if he could see anything and he had no luck.
If I go over harsh bumps, it all seems fine with no noises or anything. Only when pulling away do I get the issue. I'm not sure what to check????
Any ideas of something I could have missed?
dac69er is offline Reply With Quote Quote
Old 4 Weeks Ago   #2
David C has donated!
Re: Clunk feeling from the front as I pull away?
On my 899 Cinq, there was a gearbox mount on the left front that would work loose occasionally and allow the engine to rock.
When it came completely undone it would fall forward…
It was only held by a couple of M8 nuts & bolts.
Don’t know if the Sporting had a similar mount.
David C is offline Reply With Quote Quote
Old 4 Weeks Ago   #3
I was thinking it was possibly the engine mounts, everything is tight though and I had filled them with polyurethane a couple of years ago.
The 899 engine has a different mount setup i believe but I will double check them though.
Old 3 Weeks Ago   #4
Checked engine mounts, all fine. Got a small tweak on the front gearbox one, but that's it.
Double checked everything else and just about a turn on the drivers side balljoint nut, so I hope it's just that.
Must have needed a few miles to settle in since everything was replaced. Fingers crossed anyway!!!!
Likes David C liked this post
Old 3 Weeks Ago   #5
Still does it
Thinking it may be the brakes perhaps? It's hard to fault find as I can't make it do it all the time, only now and then.
Old 3 Weeks Ago   #6
Tricky without feeling/hearing it, but could be the pads shifting slightly.
I once had a slight clonk under my feet, which was the wishbone balljoint, fixed with a new wishbone. But you’ve replaced those, so hopefully not that.
Old 3 Weeks Ago   #7
They are clean and free, so maybe once they get some crap and brake dust in them they will stop moving about. They don't have any anti rattle springs or anything, so could be as simple as that.
It doesn't really feed like a balljoint gone, it is very hard to explain and as it doesn't do it all the time, that doesn't help as others can drive it and have no issues.
Old 2 Weeks Ago   #8
Driveshaft (inner CV joint/spider) might clunk.
They tend to make more noise when the suspension is extended, so uphill with a couple of concrete in the boot (if the car can do it) would reveal grumbling or rumbling.
Ralf S.
No bullets for chaingun
Ralf S. is offline Reply With Quote Quote
Old 2 Weeks Ago   #9
I've had grumbly inner driveshaft joints go on one of my other cars and that just gave a vibration under light acceleration and a light grumble sound. They weren't even that bad.
For them to clonk they would have to be completely thrashed surely? There isn't any perceptible movement that I can feel either.
My dad suggested undoing all the suspension bolts and doing them back up.
He also mentioned the steering rack and the uj that connects the rack to the column. Worth a quick look I guess....
Likes Ralf S. liked this post
Old 2 Weeks Ago   #10
Checked steering rack. Undone everything underneath, lubricated everything I could and retightened.
Went for a drive and initially it felt ok then all of a sudden started feeling like a balljoint was gone. This is probably the worst it has felt.
I guess it could be a balljoint, but i wound have expected them to last more than about 100 miles!!!!
The arms I removed had play in the balljoints and they were nothing like this!?
Any other suggestions?
Old 2 Weeks Ago   #11
Its Adventure Time!
blu73's Avatar
Trader Rating: 2
blu73 has donated!
Skate Boarder Champion
100% certain its the front?? could it be the rear arm bushes? they are really hard to diagnose sometimes, knocking ones don't normally even come up on a MOT cause its hard to tell theres play there...
Finn: Panda 100HP
Oberyn: Suzuki Ignis Sport
PEX: Cinq Track Car
Some previous cars: Bravo HGT, Cinq 16v, Sei Turbo, Punto GT, Panda Mania 1242 mpi
blu73 is offline Reply With Quote Quote
Old 2 Weeks Ago   #12
Quote Originally Posted by blu73 View Post
The rear was completely stripped and rebuilt. It has new poly bushes and new rear dampers.
I have double checked everything for tightness and it all seems fine.
I'm pretty sure it's from the front and you can feel it through the steering/pedals.
My dad suggested that it could just be the cheap front suspension arms have either the wrong taper on the pin so are not actually seating down 100%
I managed to get a quater turn extra out of one of them so need to give it a test to see if that solves it. If not I am tempted to just bite the bullet and buy some decent brand arms and see if it is just that as I am running out of ideas fast.
Old 1 Week Ago   #13
Its Adventure Time!
blu73's Avatar
Trader Rating: 2
blu73 has donated!
i think i'd be inclined to change the rear gearbox mount.. you said earlier in the post you checked the engine/gearbox mounts but i'm not exactly sure what checking them means... this does sound like classic rear box mount symptoms, just nipping the bolt up won't help and you can't really see it without dropping it off. Cost of a new one and ease of changing it i think its worth just replacing that first.
Finn: Panda 100HP
PEX: Cinq Track Car
Old 1 Week Ago   #14
i removed them and inpsected. i also jacked the car up in various places to check for movement.
if i drive along in first and keep flooring the throttle to make the engine swing back and forth i dont get any lumping or banging as though anything is moving about from that perspective.
the rear mount is about 18 months old and i filled it with polyuerethane, so its stiffer than normal. i would very much doubt it is that, but i agree, the cost for a replacement is minimal so it is somehting i could change.
Old 1 Week Ago   #15
Its Adventure Time!
blu73's Avatar
Trader Rating: 2
blu73 has donated!
its an interesting one to be fair, no knock with engine rocking, no knock from bump, only pulling away... mmmmm, i'll ponder this one a while longer but with all you've changed it is hard to think of anything else lol..
has it done it ever since you swapped everything or just something that came on after? stuff like this is so hard without experiencing it yourself first hand lol
Finn: Panda 100HP
PEX: Cinq Track Car
(G) Front Suspension Clunk Noise umanemo Ducato 15 03-03-2018 14:04
(T) 'Loose/Clunk' feeling on gear change (500S 85 TA) DBunX 500 4 28-08-2015 21:02
(T) Clunk from front underneath. Zog Scudo 20 11-09-2014 15:41
(T) Front suspension clunk Philjay51 Grande Punto 6 28-08-2013 15:38
