im Axle Specialists
Old 05-09-2021   #1
Brake Shoes and Handbrake Cable
I'm attempting to replace both rear wheel brake shoes on my Seicento 1.1 (2001). The handbrake cable was changed less than 12 months ago.
Having done one side only, with new shoes on, shoe springs in, actuater/linkage pivot pin freed and copper greased, and with the drum back on, I can't get the actuater/linkage connected to the handbrake cable without the shoes being tight onto the drum. I've slackened the handbrake adjuster nuts as much as possible and the cable is free here, but still the linkage arm won't pull back enough to connect with the cable without pulling the shoes onto the drum. Any ideas please? I'm only a novice mechanic.
Might it be the cable that is seized up? I assumed that it would be okay being less than 12 months old?
Might it be that I need to release the cable from the other wheel?
While on here, is it possible to remove the shoes without taking off the hub nut when the hub doesn't have cut outs? The other wheel, yet to be done, has such a hub.
Thanks,
Andrew
CasLad is offline Reply With Quote Quote
Old 05-09-2021   #2
David C has donated!
Re: Brake Shoes and Handbrake Cable
Have you tried moving the shoes on their friction adjusters?
Basically the pivot point on the shoes are not fixed, they move to give adjustment, but you'll need to lever them.
2003 Audi TT 3.2v6 DSG
2012 Renault Twingo 1.2
x1999 Alfa 156 Selespeed
1994 Fiat Cinq 899cc
David C is offline Reply With Quote Quote
Old 06-09-2021   #3
Thank you David,
No I haven't done anything with the friction adjusters. I've attached a picture. Do you mean the spring held circular piece (arrowed)? If so, is this not fixed and do I have to push a screwdriver through and move it to one side? I've tried this on a shoe that I've not yet installed and I wouldn't say that I could see any movement.
Thanks in advance.
Andrew
Old 06-09-2021   #4
jackwhoo is offline Reply With Quote Quote
Old 06-09-2021   #5
Quote Originally Posted by CasLad View Post
Thank you David,
Thanks in advance.
Andrew
You fit the shoes, then literally lever them in so that the drum only just clears.
Is the handbrake cable moving freely at the brake end?
Old 07-09-2021   #6
Odd you are having that issue. I have always struggled to get the handbrake tight enough. I have had to weld some extra metal on the handbrake leavers for the drums to allow me to get the handbrake working without having to pull it up 400 clicks in the lever!!!
dac69er is offline Reply With Quote Quote
Old 07-09-2021   #7
Thank you. I'll have a go at it in a day or two.
Yes the handbrake cable is moving the linkages okay.
Andrew
Old 09-09-2021   #8
Update:
I got everything connected in the end. A hammer came in useful and the cable adjuster is right at the very front. But the handbrake is the best it has ever been and regularly freeing and greasing the linkage pivot is a job that I should have started years ago. There are actually benefits of removing the hub.
As an aside, does anyone know where one can buy those wheel alignment screw in bolts?
Thanks,
Andrew
Old 15-09-2021   #9
The wheel alignment screws are Fiat genuine parts only. but cost about 13 each, so you have to really want them.
You can get the same result using just a threaded rod and a lock nut.. but I haven't experimented with such a setup.
Ralf S.
No bullets for chaingun
Ralf S. is offline Reply With Quote Quote
(G) 16V Mk2 brake shoes and handbrake adjustment Kirok Punto (Mk2/2b) 5 15-05-2018 08:00
(T) Handbrake cable brake drum clips Avocet Grande Punto 0 24-04-2017 15:12
(G) Costs - Rear Shoes, Handbrake Cable and Trailing Arm darkharbours Punto (Mk2/2b) 3 09-08-2010 16:44
(T) Handbrake cable,shoes or both? 1mcduk1 Cinquecento / Seicento 31 13-01-2009 21:51
(T) Rear Brake Calipers (Handbrake Cable Removal) Neojames2k X1/9 4 20-04-2005 17:41
