So a while back I had a persistent detonation issue in my 899 swapped Robin, eventually tracked it down to 0.5 bar fuel pressure and turning it up to 1.2 sorted it, until I popped a ring last year. Got a new engine in with new throttle body and issue is back. I say new tb, just the top half with reg and injector.<br />
<br />
Tested yesterday and pressure was down at about 0.75 bar, adjusted up to 1.2 as previously but this time it's still knocking. When engine is cold it starts at around 3000 RPM, it'll rev higher when it's hot but under light load, or trying to hold over about 65 mph it knocks like a Jehovah's witness.<br />
<br />
Any ideas? Kind of hit a bit of a dead end this time. I'll try to check fuel pressure while driving later on if parts arrive from Amazon in time.
<br />
<br />
