Old 1 Week Ago   #1
Portugal
Help! - Old Drum case doesn't fit on new Brake shoes?
Hi guys.
So i changed the Left rear brake shoe kit on my Cinquecento 899c 98 together with the wheel cylinder (purge it well as well) . Took me quite a while.. Those springs really are tricky.. But after everything is in place i couldn't put back the old Drum case.. I tried every way.. And the only way I could was to sand the new shoe lining a bit.. But it fits just barely as I could put it back and screw the wheels.. But even with the emergency brake all the way down.. I can still feel some resistance on the wheel.. That doesn't spin freely.
My question is.. Is any kind of adjuster for the shoes? Or is just the case of sanding the shoes a bit more?
You can see on the photos the new brake shoe kit (where the drum doesn't fit) and the other rear side (Right) of the untouched brake shoe kit just for comparison.
Thank you Guys I really appreciate it.
ID:	218256   Click image for larger version
ID:	218258   Click image for larger version
Bolinhas899sx is offline Reply With Quote Quote
Old 1 Week Ago   #2
David C has donated!
Re: Help! - Old Drum case doesn't fit on new Brake shoes?
It is a friction adjuster.
You simply lever the shoes in until the drum only just clears.
But if there is a lip on the drum, you need new drums.
2003 Audi TT 3.2v6 DSG
2012 Renault Twingo 1.2
x1999 Alfa 156 Selespeed
1994 Fiat Cinq 899cc
David C is offline Reply With Quote Quote
Old 1 Week Ago   #3
Portugal
Thank you very much David.
And where can I locate that friction adjuster?
Sorry David, English is not my first language, what do you mean by a lip on the drum?
Old 1 Week Ago   #4
The friction adjuster is the large silver disc on each shoe.
To adjust, you simply lever the shoe inwards with a screwdriver.
The clearance between the shoe and the drum needs to be VERY small.
Old 1 Week Ago   #5
Portugal
Ok, i will try it tomorrow and see.. If the drum still touches the shoe, do you recommend sanding it?
I even though of releasing the tensioner of the Emergency Brake to the lower setting to see if that would "push"/retract the shoes more to the centre by moving this piece (on the back, that looks to be the one responsible for the E-Brake) .. But that didn't do much.. 🤔🙄
Old 1 Week Ago   #6
Portugal
I'm desperate guys!
So i was able to put the Left drum on with the new shoes.. Don't aak me how.. Just fiddling and fiddling with the shoes position and a bit of sanding..
But the Right side i simply can't.. It just doesn't want to fit!.. The E-Brake is all the way down, I still haven't purged the wheel cylinder (has i was wanting to fit everything first..)
Any tips guys?
You can see the old in comparison with the new one (fitted), the pads are slightly slimmer than the new ones.. First i thought it was from the 20 years of wear, but now i don't know.. I don't want to put the old ones as the springs are a nightmare..
Anyone know any trick?
ID:	218310   Click image for larger version
Old 1 Week Ago   #7
Italy
It sounds like your missing something.
1. Make sure you have handbrake off (wheels choked, car in gear).
2. Brake master cylinder refill cap is off (if your not sure where it is see left hand side of attached picture)
This will allow you to push in the brake cylinder as pictured on the right hand side of the picture. then the brake drum will fit.
If you are sanding down the brake pads there is no point changing to new ones as you are wearing them down when your fitting them
Chris parry is offline Reply With Quote Quote
Old 1 Week Ago   #8
The shoes can usually be slid up and down a little to centralise them
if they are a little to far one way or the other the drum will be hard to fit.
This is only a very small amount but it does not take much.
http://https://badges.fuelly.com/images/sig-uk/1043335.png
If you find a fix for your problem please let us know it will help others.
RalphM is offline Reply With Quote Quote
(G) Brake Drum and Shoes need replacing? rundle123 Punto Evo 45 24-05-2019 09:55
(T) Brake Drum doesn’t fit ReKone 500 (Classic) 9 26-07-2018 00:38
(T) Panda MJ Drum Brake Shoes .How Hard to Fit ? ytareh Panda 25 02-04-2015 15:40
(G) Panda Multijet 2005 Drum Brake Shoes .How Hard to Fit ? ytareh Panda (2012+) 2 14-12-2014 00:07
(T) Rear drum won't fit over shoes csmorris Bravo / Brava 6 31-07-2009 17:18
