Can someone tell us how the fuc.k do you disconnect the the coolent hose. The lowest bit it? looks a permanent join to me. Why cant Fiat just make the simple maintenace jobs easy & simple to carry out??????
if you are referring to the pressed joining clips then the easiest way fro me is to prise them off with a screw driver and replace with a screw fit jubilee clip
well I'm trying sort the same thing really. The hose right down the bottom but hasn't got a jublee clip on it. It looks just like normal water pipe but I'm trying to pull it!!! to drain the coolant out??
