fixitagaintomorrow said:You need to use the Cento crank position sensor, Cento oil pressure switch complete with long hollow bolt and 90' elbow.
Using the cento tdc sensor is fine, mine still works - but the oil pressure sensor does not. I smashed it a bit when i was replacing the rad a while ago.
I went to the scrappy and took one off a mk1 Sei sporting, and it looks the same as a punto one. No 90degree bend in it. I also have a sensor of Sie's yellow cinq, which although has the connector a bit smashed - still no bend in it.
Did they change something, or am i going mad?
