Old 3 Weeks Ago   #1
adjustable clutch?
Hello
I'm finding I need to push the clutch all the way in to get it into first gear, otherwise it is difficult to get it in. The clutch is fairly new. I recall that the clutch can be adjusted, is that what is needed here? If so, how do I do it?
Phil
'97 Cinquecento Sporting - Imola blue
Alpine26 is offline Reply With Quote Quote
Old 3 Weeks Ago   #2
David C has donated!
Re: adjustable clutch?
There is an adjuster at the gearbox end.
A couple of spanners needed, can't remember what size, about 11mm I think.
(assuming the Sporting is similar to the adjuster on my old 899)
2003 Audi TT 3.2v6 DSG
2012 Renault Twingo 1.2
x1999 Alfa 156 Selespeed
1994 Fiat Cinq 899cc
David C is offline Reply With Quote Quote
Old 3 Weeks Ago   #3
Its Adventure Time!
blu73's Avatar
Trader Rating: 2
blu73 has donated!
Skate Boarder Champion
yes, as above, adjustment nut on end of the cable at gearbox end..
adjustment specs are in the haynes, you get a feel for it once you've done it a few times but you measure the distance the pedal travels and adjust until its in spec.
But essentially what you are doing is tightening the cable until there no slack or tension in it and the clutch arm hasn't moved - too tight and the release bearing will drag on the pressure plate all the time and they'll wear fast, too slack and you don't quite get enough travel to fully release the clutch.
Likes varesecrazy, David C liked this post
Finn: Panda 100HP
Oberyn: Suzuki Ignis Sport
Urchin: Alfa 159 SW
PEX: Cinq Track Car
Some previous cars: Bravo HGT, Cinq 16v, Sei Turbo, Punto GT, Panda Mania 1242 mpi
blu73 is offline Reply With Quote Quote
Old 3 Weeks Ago   #4
varesecrazy has donated!
Quote Originally Posted by Alpine26 View Post
Hello
Probably just 'bedded in'
Yes 2 x 10mm spanners required at least one an open ender..
A tube : box spanner is good for this job
varesecrazy is online now Reply With Quote Quote
Old 3 Weeks Ago   #5
cheers all
I have located the two nuts, I think the first one is a locking nut and it is the second one that adjusts the cable.
I need the point at which the clutch engages to be a little further away from the bulkhead. So do I need to lengthen the cable (so undue the nut), not shorten it?
Phil
Old 3 Weeks Ago   #6
You need to tighten it up if it struggles to get in gear.
dac69er is online now Reply With Quote Quote
Old 3 Weeks Ago   #7
Yes you need to tighten it.
The measuring distance is from the steering wheel to the pedal.
Iíll check my old Haynes later for the measurement unless someone else replies before then.
Old 3 Weeks Ago   #8
thanks, if you have the measurement to hand David that would be great, although I did find this (if the link works) that refers to measuring the pedal pushed in compared to let out
https://www.fiatforum.com/attachment...6&d=1403631396
Thanks slugworth1987 thanked for this post
Likes slugworth1987, David C, varesecrazy liked this post
Phil
Old 3 Weeks Ago   #9
120mm was the measurement that popped into my head last night, but I didn't want to commit it to the Internet without checking first..!
Haynes has:
120mm +/- 5mm for the OHC
110mm +/- 5mm for the OHV
Thanks slugworth1987, blu73 thanked for this post
Old 3 Weeks Ago   #10
great, thanks David
Phil
Old 2 Weeks Ago   #11
The Ratter
slugworth1987's Avatar
slugworth1987 has donated!
I was just about to ask the same Q!! Saved the details and will have a go at this later!
Likes blu73 liked this post
slugworth1987 is offline Reply With Quote Quote
Old 2 Weeks Ago   #12
Its Adventure Time!
blu73's Avatar
Trader Rating: 2
blu73 has donated!
Quote Originally Posted by slugworth1987 View Post
you made a thread for your new purchase yet??
Finn: Panda 100HP
Urchin: Alfa 159 SW
PEX: Cinq Track Car
Old 2 Weeks Ago   #13
Am having trouble holding the cable still while I turn the nut on the end, the cable is turning. What's the best way to hold the cable in place? Access is tight.
Phil
Old 2 Weeks Ago   #14
Its Adventure Time!
blu73's Avatar
Trader Rating: 2
blu73 has donated!
not a problem ive had but id imagine i'd grab some pliers or mole grips if was there
Likes Alpine26 liked this post
Finn: Panda 100HP
Urchin: Alfa 159 SW
PEX: Cinq Track Car
Old 1 Week Ago   #15
The Ratter
17mm deep reach on the nut and moles on the threads worked ok for me yesterday
Likes Alpine26, blu73 liked this post
(G) adjustable boot Munchy94 500X 1 19-11-2016 15:45
(G) Stilo 1.9JTD Dynamic (adjustable clutch?) Allyssa Stilo 8 25-08-2015 23:26
(G) adjustable coilovers bensyellowhgt Punto (Mk2/2b) 11 31-08-2010 22:45
(G) Adjustable Thermostat hebby Marea 3 10-07-2007 13:51
(T) Adjustable Clutch on Fiat Punto MK2 5 door? madbiker51 Punto (Mk2/2b) 2 06-11-2006 12:34
