Old 10-12-2005   #1
GTI Till I die
Randomman's Avatar
Randomman has donated!
Free Lancer Champion
Still unsteady idle
Well I loosened the throttle so its sits happily when on idle, but the problem of a rough idle is still there, with it dipping and rising, sending a shudder through the car. This only seems to happen when its warm?
I'm checking gaskets again this weekend and making sure my botch job is up to scratch on the Throttle body.
Any more suggestions? Someone mentioned a Lambda last time, what other symptoms would come along with this?
Team TD 124.9bhp & 209.1 ft/lbs torque
Quote Quote:
if you could get a jtd up to 7k you'd be doing 223mph
Cereal!? Ha! I eat cereal for breakfast!
Randomman is offline Reply With Quote Quote
Old 10-12-2005   #2
Banned
Oldschool has donated!
Re: Still unsteady idle
You have an improved induction kit.
You have an improved throttle body.
You a much higher lift cam.
You have an improved exhaust.
You have a considerably bigger engine.
Have you thought about it that the mapping might not be up to delivering the fuel? When the engine is cold the ECU does the same as a choke. It injects much more fuel to overcome the fuel condensation.
The MCkrich chip most likely is not up to it. Don,t get me wrong. I do not want to claim that the chip is no good. But don't forget it was not done for the setup you have.
Otherwise I only can think of the idle control.
Oldschool is offline Reply With Quote Quote
Old 10-12-2005   #3
GTI Till I die
Randomman's Avatar
So its not a symptom of lambda then?
Thats good to hear
Now the question is do I get a re-map now, or wait for a few months untill it goes ptsschh??
Decisions decisions. . .
Quote Quote:
Old 10-12-2005   #4
arc
this is where i stand
arc has donated!
you could clean the idle control valve out, but as Peter said its probably due to the engine not being very standard anymore.
The shudder when warm isn't the revs dipping as the fan kicks in is it?
.:: 1368cc 16v Cinquecento ::.
arc is offline Reply With Quote Quote
(G) Another Idle Problem - Please help Soj Uno 1 26-07-2005 16:36
(T) 1.1 i.e. timing belt/cambelt and poor mixture (idle fault) andre79ge Uno 7 12-04-2005 17:36
(G) UNO 1.1 i.e. idle problems and iar leacks andre79ge Uno 7 21-11-2004 02:10
(T) 1.8 MW : weird idle behaviour chestnut Stilo 14 18-11-2004 21:16
(T) [Tipo 1.6 ie 94] Injection light and idle Malex Tipo (Classic) 1 28-07-2004 22:18
