If the noise occurs as a single skwwek as the clutch goes down, then lubricate the mechanism both at the drivers side and the passengers.
If it is a motion skweek that happens as the clutch stays depressed, then release bearing/clutch cover are not mating correctly. Needs a box out and clutch change.
D
