Technical Had your tb apart recently?...
Banbury, Oxfordshire
If you have do you know what the bolt holding the tb in place? was it a allen key (however u spell it :p) bolt or was it a stud and nut? pics below, as you can see the bolts i picked up from scrappy alot shorter than the stud i did have on there (that i snapped one of) and im thinking of phoning fiat to see if they will post something so small/cheap (65p inc vat according to ePER) listed under part num 7738332 and as being M6X95 (Wish i knew what that meant, im sure it looks longer than 10cm so cant be that surely? :eek: )
Can anyone help me at all? :eek:
just had a measure, im guessing the M6x95 means the length of the bolt, just had a measure of the bolt that i got from scrappy (same ones both off a punt 55 and a cinq 899) including the allen key fixing bolt head its ~10cm long but measuring after that its 95mm long (guessing the 95 stands for this) but the stud that came off is 115mm long :( the allen key bolts i have reach the bottom of the spacer (have looked at both the 40mm tb and the 30mm so its not that :() but wont stick out from it at all so not long enough :(
And cheers for offer of postage custard, will let you know :) your a legend :worship:
ok i now want to bang my head against the wall repeatedly... i got a load of bolts just incase something happened to these, some off 899 some off punt 55... and turns out the 4 i pulled out were all the 899 ones, and the one remaining punt 55 one is long enough :eek: so now just need to sort out that coolant pipe :slayer:
And its probably a fine thread pitch too, so is probably an M6 x 1.00 x 95 bolt
The bolts on our 899 are all standard hex head.
I think they are Identicle to the ones that were on our punto 55 as well. Infact i'm damn sure they were the same length.
Doubt that helps though.
:D
Jon+Em
