Technical leaking
Technical leaking
luke64
Member
has any one had the problem of having a soakin wet boot its happened 2 times now first time i jus thought i mite of had the boot open at footie an lil bit of water got in but today its soakin but there doesnt seem to be a leak does any one no of any think it could be?thanks luke
The old classic of the rear clusters not being refitted properly likely, simple to take them off and carefully refit to allow a proper seal.
Liam
whats a rear cluster an sorry an my driver foot well is soakin wet dont no why had this b4 but i sorted the leak out from under the battery try an i know it isnt that so any ideas
The rear lights seal to the body with a foam rubber gasket. This often isn't replaced properly and it can leak. Water runs down the back of the lights (past the gasket) and gets into the car through the holes the wiring for the lamp bulbs goes through. Take one of the lamps of and you'll see what I mean.
You can tell which one is leaking by looking inside the boot, under the lights. You'll have "channel" marks where water has run in.
Ralf S.
