dedradan92
Member
- Feb 8, 2014
- 26
- 93
Hi Guys,
I'm doing a Punto 75 engine swap(with P75 ECU) on my Spi Seicento Sporting and I've 2 questions as regards the wiring. I was wondering if I can keep my standard seicento loom so long as I connect the 4 injectors to the Spi injection wire?(Will any wires be going to the wrong place in the ECU?) and if this is possible, can I source a female wire connection similar to the Spi injector(picture) and wire it to the 4 male plugs from the P75 injector? (Creating a sort of mini-harness)
The reason I'd like to do this is to increase the simplicity of the swap. Ive done 899 to 1108 and it was nice having all the bits ready to install like an off the shelf conversion. I've already sourced the Palio manifold so I can avoid modifying the P75 one.
Thanks, Looking forward to your responses.
