Just changed the cambelt on my 2001 Sporting Seicento. The tensioner was squealing like a thousand tortured gerbils, and sure enough, the one removed was only just able to rotate. It ran fine, but made a hideous noise til warmed up. Replaced tensioner, belt and water pump.
It's back together and seems to be running fine again. Far as I can tell it's the same as it was, but without the squealing. Revs fine, runs smoothly, idles fine cold and hot, temperature seems fine . . oh, no, wait, haven't fitted the temp gauge yet
If you want to hear it look on YouTube "My Seicento after cam belt change" by Airship17.
Anyway, why the post? Well, when I was fitting the new belt, I rotated the engine as suggested to line up the marks on the oil pump cover and the head. It has the single notch on the head for the cam pulley and the corner on the oil pump cover for the crank pulley mark as per manual pics. It lined up fine on both as far as I could see. I used an inspection mirror so I could sight across the mark on the camshaft pulley to the mark on the head, square-on.
However, when I fitted the new belt it was not possible to get the pulley marks on the engine marks but also to get the yellow lines on the belt on the pulley marks. The belt marks were out by one tooth, which left me in a bit of a quandary. Eventually I concluded that the engine marks are permanent and had to line up, whereas the belt lines could be for a different model, etc. Or the water pump pulley diameter or shaft centre could differ so more or less belt (by one tooth) between the pulleys - the pump I fitted has 24 teeth same as the old one but maybe there is a newer type with fewer and hence a smaller pulley.
Anyway, as above, it seems to be running fine, not any different than before apart from the noise is gone. Is this a known thing? Has anyone seen it before? Would it be obvious if it was a tooth out? Sorry, I didn't get pics as I was in a hurry by then. If there had been no marks on the belt I would be fine with it all . . . Comments gratefully received, thanks.
