Old 17-09-2019   #1
Cinquecento Sporting clutch cable help needed
Hi
I have the 'clutch pedal on the floor and won't come up' issue. (1996 Sporting.)
having searched other threads it seems I need to check gubbins in the passenger footwell. Is the carpet glued and has to be pulled up?
any advice on accessing the gubbins i need to check?
thanks
Steve
Sprevett is offline Reply With Quote Quote
Old 17-09-2019   #2
Banned
Re: Cinquecento Sporting clutch cable help needed
It's up and under the parcel shelf. No carpet needs disturbing.
You'll need to move the passenger seat back as far as possible and stick your head under the shelf.
Options to get in are to hang your legs out the door, or fold the seat as flat as possible to get your legs on it.
The cable will have broken at the J clip, as it has a designed in weakness so it breaks before anything else.
Schumi2001 is offline Reply With Quote Quote
Old 17-09-2019   #3
Thanks that's helpful and I've had a look, yes the cable has snapped at the pivot.
Is it likely the clutch is on its way out? or is it just metal fatigue.
Last question - is it a DIY job for a reasonably able amateur!??
It looks like the 'hook' connects with a split pin, easy enough i guess, but the other end in the engine bay looks fiddly to get to, and will it need to be correctly adjusted, needing a pro who knows how to do such things?
thanks
Steve
Old 17-09-2019   #4
I'll just leave this here. Not for the sporting, but might give you an idea of what's involved.
Jamieboy is offline Reply With Quote Quote
Old 17-09-2019   #5
thats great thanks!!
Old 17-09-2019   #6
Its probably snapped because it needs a new clutch. If your hissy swapping the cable buy two because it may well happen again at some point.
Press the clutch with engine off - If it's heavy'ish and makes creaky sounds then it's the springs getting old and harder to operate in the clutch pressure plate.
New clutch will make pedal feel lovely and light
purf is offline Reply With Quote Quote
Old 18-09-2019   #7
Hmm ok new clutch probably sensible given that the car is a keeper with only 36k miles on it. Can you give any idea of cost typically? Is it a pig job or an easy job?
Steve
Old 18-09-2019   #8
Autotest Special
rallycinq's Avatar
Trader Rating: 1
rallycinq has donated!
Clutch on a Cinq is dead easy, a one spanner rating, if that.
The box is light enough to come in and out through the wheel arch.
For changing clutch cable, take the passenger seat out, its only 4 bolts.
D
Old 18-09-2019   #9
Awesome thanks Iíll do it!
Fiat 132 S Clutch Cable needed. FiatClaudia Newbie Central 4 22-01-2015 18:48
(T) clutch cable adjustment after 100/150 miles ? with new clutch cable and clutch ROBTECH Cinquecento / Seicento 3 25-11-2013 01:17
(G) Cinquecento clutch cable simo101 Cinquecento / Seicento 8 12-01-2012 19:53
(T) Rod and cable clutch Cinquecento dexand Cinquecento / Seicento 3 04-02-2010 16:28
