Hello guys,
So, since most stuff here seems to be about seis and I have a cinq, I'm going to ask a few questions and try to solve this issue or at least "fix for now".
The temp gauge was taking a long long time to hit the 90ºC, so I flushed the system (so much orange crap and water), the thermo was broken open, so it wouldn't heat and got replaced by a new one, and the temp sender (red on the engine block), got replaced also.
So, now the car hits around 90ºC and the thermostat opens and stays around there, everything fine by now. The issue is, I do believe the head gasket is bad, so that's why it get hotter when its idling and I'm trying to know when the radiator fan kicks in. I disconnected the radiator temp sender wiring (the conector to the sender unit) but it didn't work, so I bypassed it and the fan is always on, even when the car is off I believe so it's not a good solution :bang:. Also, sometimes, before hitting the 130ºC second mark, sometimes the fan decides to start... the thing is, I'm afraid to test without knowing if it is normal or not to start at that temperature (a bit less)...
I need to know if there is a way to bypass the fan, so it always stays on, or to test the temp sensor in the radiator to start the fan (Ohms expected etc)
Thanks so much!
Thanks so much!
