Old 19-07-2019   #1
Suspension bolt thread specs
Ragazzi,
I'm in the middle of swapping the rear subframe on Titch, the Younger Mrs S.'s Cinquecento for solid one from a newer model that I've recently bought, had blasted and re-coated.
Currently the wheels and swing arms are off and I've seen a load of holes in the top of the old sub-frame (worse than I feared) and in the chassis rails... which I'll have to sort... but I'm also going to replace all the sub-frame and damper bolts for new ones.
The bolts seem to be "super-fine" spec'... that is M10x1.0x35mm for the dampers... but as far as the subframe bolts go, I've seen super-fine in both 1.25 and 1.0 spec'.
Does anyone know the proper spec'? I have the bolts half out (a bit seized, to say the least) so I may eventually be able to measure them.. but it would be handy to know in advance.
Ta,
Ralf S.
No bullets for chaingun
Ralf S. is offline Reply With Quote Quote
(T) elx 90 cylinder head bolt torque specs cncuser Punto (Mk1) 2 31-05-2014 08:07
(T) bolt thread size Dom130 Grande Punto 1 21-11-2009 01:40
(G) bolt hole thread kev uno Uno 5 29-05-2009 12:16
(G) Wheel Bolt Thread stealthstylz Uno 4 13-09-2007 16:33
(T) Help! Wheel Bolt Thread Length dlhuss Barchetta 4 25-05-2007 14:53
