j333evo, been told you can help - Alloy's, can someone please check this?
Hi everyone
I've just bought some new ally's for my sei, and i've done some calcs to find the spacers that i'll need to make them fit as they should.
Was hoping someone could say "Yes, thats right" or "no, your a muppet, this is what it should be"
I've gone from the std 5.5JX13 ET29 rims to a 6JX14 ET35 rim. The inside of the new rim rubs ever so slightly on the end of the steering arm at the moment - so i cant fit them yet.
Soooo this is what i thought
If it were a straight swap to a 5.5JX14 rim, i think i'd just need a 6mm spacer to return ET from 35 to 29mm as standard. Is this correct?
However, as i've gone to a 6J, that is .5" wider - 12.7mm to be exact, i will need another 12.7 / 2 = 6.3 mm added to the spacer to take into account the wider rim
So basically what im saying is i think i need either a 12mm spacer - is that right? From looking at it when fitted, and where its rubbing, i reckon i could easily use a 10mm, but i'll see what you guys say
Also, anyone on here fitted a 195/45 tyre to a 6J rim? Coz thats what i want
TIA
Dale
Hi everyone
TIA
Dale
