FIAT Auto Specialist Team
Old 25-06-2019   #1
Fuel Cap Leaking
I have a leak from my fuel cap. I have bought a replacement cap just in case the cap itself was faulty, but no luck and it still leaks.
I have noticed that there is a metal collar just inside the filler neck that is loose on my car. It looks like it usually helps to seal the fuel cap and I wonder if being loose is causing the fuel cap not to seal correctly?
Has anyone else had this? Can I bond the metal collar back in place somehow to save me having to replace the whole filler neck?
markf is offline Reply With Quote Quote
Old 26-06-2019   #2
Autotest Special
rallycinq's Avatar
Trader Rating: 1
rallycinq has donated!
Re: Fuel Cap Leaking
If the bayonet in the pipe is loose, that will be your issue. Probably best to pop it out and see why its come loose.
D
Old 27-06-2019   #3
Titch, the Younger Mrs S's Sporting has the same issue with a loose metal dibber-dobber (the yellow zinc plated piece).
I don't have a solution though. When it gets moody, I have to move the piece around by hand so that the square notches in the otherwise round hole are aligned with the front & rear "line" of the car. Then the cap fits in and seals okay.
Ralf S.
No bullets for chaingun
Ralf S. is offline Reply With Quote Quote
Old 30-06-2019   #4
That's very interesting to read, Ralf.
I have the same issue (apparently) as an MOT advisory on a 'period Alfa-
I had always assumed it was the rubber; it didn't occour to me there could be a mechanical component to the problem..
I'll need to look aT it sometime!
dante giacosa is offline Reply With Quote Quote
(T) Coolant leaking from filler cap....why?? Scudoria Scudo 7 16-01-2020 14:50
(T) Fuel leaking from fuel cap Palio1998 Palio 1 13-10-2015 06:13
(G) Steel fuel pipes corroding..leaking fuel lancia8888 Multipla 3 06-02-2014 21:16
(T) Oil filler cap leaking Dewi50 Ducato 11 03-12-2013 20:30
(T) Oil leaking from filler cap - Cinq Sporting wolvescinq Cinquecento / Seicento 3 21-03-2011 20:50
