Fiat Seicento instrument panel changing
Rogerilo
Hello,
Is it possible to change the mk1 instrument panel into a mk2 instrument panel with the display in the middle? Size seems the same, but totally different connectors on the back. Has anyone tried this?
I’m sorry, please change this thread into the Seicento side of the forum!
I'm guessing it's to be filed under 'lots more hassle than it's worth'.
The facelift instruments will be taking mileage and possibly speed from the ECU. (I haven't looked closely enough to verify).
Pre-facelift with a mechanical mileometer will be cable driven, hence the difference in connectors.
Okay, my ‘old’ instrument panel’s meters are dancing when the car is driving, so I thought of replacing it with a new one. And then why not with the mk2 version! But maybe the idea is a little over the top.
If I replace it with another same instrument panel, how do I correct the kilometres on it?
Bouncing around cable driven instruments is often caused by a sticking or damaged drive cable or the wormdrive gearbox.
Bouncing around electrical instruments would be a bad connection somewhere.
Some gearboxes have grease filled bearings. Is that the case with some Fiat boxes?
The issue with this system is that bearing inner seals wear allowing gearbox oil into the bearing. The overfilled bearing churns its lubricant, overheats and the bearing seal blows-out. Bearing now runs dry. :(
With the Fiat wet boxes the inner spider is inside the box, lubricated by the gear oil.
The driveshaft boots are fixed to the gearbox and the shaft turns in a bearing in the outside of the boot.
These boots/bearings can leak letting all the gearbox oil out leading to wear problems in the diff and box.
D
