Over the last week my sei sporting has been drinking water. I got under the car yesterday to investigate and can't seem to see exactly where the leak is coming from.
It looks to be coming from the area around the oil filter and cam belt. I checked the radiator and this is fine, no signs of water loss from this or pipes surrounding it. Also none of the usual signs of head gasket problems so don't think it is this. It doesn't loose much when at standstill but when I check after a trip it's lost a fair amount.
I've done a quick search on the site and the water pump seems the most likely problem - does this sound right for the symptoms or should I be looking for anything else before replacing this?
