- Jan 16, 2006
- 46
- 21
Hi to all, I own a Cinquecento Sporting 1.1 SPI.
I'm trying to understand if displayed temperature is correct.
On unconnected wire of temperature sensor from ECU I read 7.76 Volts (shouldn't be 5?), while on shortcut I read 120mA.
So internal resistor of ECU is 64.6 Ohm.
I connect 150 Ohm resistor instead temperature sensor: gauge says 90 °C.
Brand new temperature sensor: the red one with 16x1.5 thread.
Placed on climatic chamber set at 90 °C (additional digital thermometer says temperature is within 89-91 °C) I measure 270 Ohm.
This means if I use this sensor, gauge will display temperature lower than 90 °C.
I'm very confused.....
Any ideas? could be the gauge not working correctly?
Thanks.
Thanks.
