Thread Tools
Old 23-12-2018   #16
Re: Rough Running
Quote Originally Posted by dac69er View Post
What fuel pressure do you have when the car is running? Have you changed the fuel filter in the line, not just the fuel pick up on the pump.
What voltage do you have at the pump when it is running?
I disconnected the fuel line at the rail and turned over the car for 30 seconds and there was 750cc of fuel.
I have traced the fuel line from tank to rail and there is no inline filter, I have posed the question and been told there is no inline filter. I have been told they stopped fitting them in 98.
https://www.fiatforum.com/cinquecent...nto-1-1-a.html
12v
nrw1950 is offline Reply With Quote Quote
Old 24-12-2018   #17
Re: Rough Running
Quote Originally Posted by nrw1950 View Post
that does not test fuel pressure. you need a gauge.
if you have only 12v, that may be an issue. when running the electrical system should be sitting closer to 14v.
dac69er is offline Reply With Quote Quote
Old 24-12-2018   #18
South Africa
Re: Rough Running
Agreed...cant guess fuel pressure. In my experience the pump filter has to be absolutely clean. Can be cleaned using good carb cleaner blown through from the outlet end. Injector spray pattern is all important not just quantity of fuel. Needs to be atomized properly. 12 volts sounds low but remember voltage can drop down a lot during cranking and engine must fire and run correctly with this demanding condition. In my experience fuel flow issues are worse when the engine is hot and not when cold which seems counterintuitive as fuel demand is higher when cold. But when hot the engine should be in a closed loop managed largely by the lambda sensors which are not used when cold..
Thanks varesecrazy thanked for this post
Frosty1961 is offline Reply With Quote Quote
Old 24-12-2018   #19
varesecrazy has donated!
Re: Rough Running
Ok.. reading between the lines here:
Car starts.. fires.. ok.. but runs ROUGH
Can be coaxed to build revs.. but struggles.
Sounding like timing..
Or incorrect temp readings adversely effecting fuelling.
Have you checked what temps the ECU Is seeing?
Old 24-12-2018   #20
Re: Rough Running
Quote Originally Posted by Frosty1961 View Post
I removed the pump and cleaned the filter with carb cleaner.
The engine ticks over on idle without using the accelerator
If I floor the accelerator it stalls but if I give it gentle on/off touches it will pick up revs and will eventually get to high revs. While holding down the accelerator on high revs it will fade in and out.
I measured the fuel pump voltage not running
There is no EML
Old 24-12-2018   #21
Re: Rough Running
Have you managed to run long enough to see if HEAT makes it better - worse ?
Old 28-12-2018   #22
Re: Rough Running
UPDATE:
Checked the EVAP valve.
Removed the blue hose and attached a vacuum gauge to the valve. It was showing no vacuum.
Checked the electrical connector with a light and it was pulsing with the engine speed
Removed the valve and checked it on a battery and it opened and I could blow through it.
Refitted the valve and still no vacuum
removed the connector and jumped the valve to the battery and got 20psi on idle
Cannot understand how I am getting power to the connector but not operating the valve.
Old 29-12-2018   #23
Re: Rough Running
The evap valve does nothing. Disconnect the pipe from the inlet if you think it is causing an issue.
Have you check the fuel pressure whilst the car is running yet?
Old 29-12-2018   #24
Re: Rough Running
I read that a faulty EVAP valve caused rough running.
The valve is not opening, so no need to disconnect it.
Waiting for a fuel pressure tester.
Old 29-12-2018   #25
Re: Rough Running
If it stays open then it would cause what is essentially a vacuum leak, so it would most likely raise the idle a bit. If you disconnect it and vent the tank to atmosphere, that will eliminate that.
Old 02-01-2019   #26
Autotest Special
rallycinq's Avatar
Trader Rating: 1
rallycinq has donated!
Re: Rough Running
Your evap will switch to earth, not live.
It does sound like a vacuum/air leak to me.
Incorrect mixture being corrected by the ECU.
D
Old 14-01-2019   #27
Re: Rough Running
It looks like it is fuel pressure, Running at 18psi. Might need new pump.
Old 15-01-2019   #28
Re: Rough Running
Disconnected the inlet pipe to the EVAP, made no difference. There are no codes showing. It runs worse when hot.
Old 11-02-2019   #29
Re: Rough Running
UPDATE: Tested the fuel pressure and it was below 1 bar. Ordered a complete sender/pump online that said it was for my model....it wasn't - sent it back and found a 3.5 bar pump on it's own....fitted that....pressure worse....found a leak in the corrugated pipe ...fixed that.... still no pressure....took complete unit out of the car to test it.... tested it on my bench sbmersed in a container of petrol and the pressure release valve was faulty so found the complete correct sender/pump unit...fitted it, now have 3.5 bar and running perfectly. happy boy!
Likes Ralf S., rallycinq liked this post
Thread Tools
(T) Running rough peter33 Cinquecento / Seicento 12 28-09-2014 08:09
(T) Running rough ljubo700 Punto (Mk2/2b) 10 30-08-2014 10:51
(T) Newb seeks advice re 1.ie running rough. Very rough. Sef Uno 3 23-06-2013 07:50
(T) Rough running afroking Barchetta 50 02-02-2009 14:19
(T) 1.6 rough running - HELP sanja141 Stilo 53 16-11-2008 23:09
