the plastic bit in the headlight that attaches to the headlight adjuster (pictured) has disintegrated.
if i buy a new headlight, does it come with this bit or is this part of the actual headlight adjuster?
Got 2 spare new headlights can check for you and let you know
[emoji106]
[emoji106]
Yes sir, I got these on autodoc, inexpensive and they came with the manual adjusters too.
They have a shop in the UK as well.
I'm interested if the bit is there that is broken on mine. If not then my current light still works and I may as well use that.
Yep
They are as new
Can take more pics for you when I’m back to the workshop
Let me know
If you could take a pic In The hole where the adjuster goes then I should be able to tell.
