What I meant was you could possibly have that linkage flipped or reversed somehow, moving the cable attachment point rearwards.
The handbrake cable is slacked to the very edge, one turn and the bolt comes off. If the cable is mounted to the elbow link, it spreads the shoes out too far.
Think he's done that.Like i said before. You need to loosen the handbrake adjustment. Underneath the car in the middle. So on the bottom of your handbrake. You need to loosen the nuts. This will give more slack at the ends of the cables where you attach them to the handbrake levers of the brakedrum.
After a lot of thinking - and realizing that i prized the old drums off - and that the backing plate is visibly bent - how likely is it that that is the culprit?
