Old 15-11-2005   #1
Trader Rating: 1
EvilJaxx has donated!
Klonk Klonk, Shocks anyone?
I have Bilstein 55mm lowering String and Bilstein Gas shocks all new, now my old shocks where destroyed by the lowering springs but now they are on the new Bilstein shocks its brilliant, i assume the bilstein shocks wont be destroyed by the springs as they are new on new !
Anyway I have a funny klonking noise coming from front right it was worse when I had the old shocks in now its not so bad but still there, I am just wondering if anyone else has this same sort of sound?
Cheers Adam
EvilJaxx is offline Reply With Quote Quote
Old 15-11-2005   #2
Trader Rating: 1
mase has donated!
Gary Golf Champion, SikTrix BMX Champion
Re: Klonk Klonk, Shocks anyone?
need to be more specific mate... coming from a particular corner? back wheels? goin over bumps? only when going round corners? wat does it sound like? metal on metal, dull thump....
the more info we have, the easier it is to diagnoise a problem and a cure!
R97 cinq 1242 <Ex Team Anthracite >
(now sold)
mase is offline Reply With Quote Quote
Old 15-11-2005   #3
taffy git
gaz.d's Avatar
Trader Rating: 2
gaz.d has donated!
mine klonked all the time until i someone put my spring on properly , was mainly noticeable going over bumps and turning
could the klonking also be it sitting on the bumpstops or hitting them going over bumps
Gaz
FIAT No More
gaz.d is offline Reply With Quote Quote
Old 15-11-2005   #4
Clubcento Member
CaneyJ has donated!
Srry to jump on thread but have similar prob with mine at the moment. It clonks/clinks/creaks with a metallic sound going over speed bumps more than 4mph.
It is most noticable with the window down and appears to come from the back end, any ideas? Pleeease don't say it's the bushes going .
CaneyJ is offline Reply With Quote Quote
Old 15-11-2005   #5
HP
I was only doing 80...
HP's Avatar
HP has donated!
Could be front bushes, track rod end, balljoint or strut top bearing.
Also the anti-roll bar can catch the bottom of the inner wing and arch liner on really low cars. Some 'percussive maintenance' may be required if this is the case.
Pete.
"Make something idiot proof and someone will just go and build a better idiot".
HP is offline Reply With Quote Quote
Old 15-11-2005   #6
hi friends :waves:
Liam's Avatar
Liam has donated!
Shortened Bilstien Shocks or just OE replacement ones?
Clonk could be a burst shocker too.
Liam
Yes it's really me!
97 Cinq Sporting-RIP 09/10/06 BYE OLD FRIEND
Liam is offline Reply With Quote Quote
Old 16-11-2005   #7
Trader Rating: 1
The noise only happens when I go over a bump its a strange klonk noise, say the word "klonk" and thats what it sounds like
Its no way as bad now as it was with my destroyed shocks but its there every now and then coming from the front right area only. Im getting the feeling its not the shock or anything to do with the suspension at all but something knocking as i hit a bump, like the battery wacking the strut brace kinda thing as I have not bracket to hold the battery down, will stick some rubber between the battery and the strut and see what happens!
The knocking was worse with the nasty shocks because obviously they where not absorbing any shock meaning whatever it is was bouncing about more but now my new shocks are taking the punishment so it doesnt bounce as much, who knows
Adam
(T) KYB Shocks ChrisPa Cinquecento / Seicento 5 05-07-2009 19:26
(T) Eibach springs + original shocks pystilo Stilo 7 12-11-2005 12:39
(T) shorter shocks. mase Cinquecento / Seicento 3 17-01-2005 13:26
(G) Front shocks.. i need help! Bushboy Uno 9 28-11-2003 15:37
