FIAT Auto Specialist Team
Thread Tools
Old 07-06-2018   #1
Speedo Adjustment for 14" Wheels?
When Fiat put the official 14" wheels onto the Seicento Abarth, does anyone know if the speedo reading was adjusted at the factory to be different from the standard 13" wheels? I put the wheel/tyre size differences into a calculator and it says the difference is too much between the two setups, including standard size tyres!
Just wondering, as considering fitting 14" wheels onto my Cinq.
markf is offline Reply With Quote Quote
Old 08-06-2018   #2
Re: Speedo Adjustment for 14" Wheels?
I think it's how the gearboxes are set up... So you'd need a gearbox from a car with 14's
curtisjwc1 is offline Reply With Quote Quote
Old 09-06-2018   #3
Moderator
henseyseries3's Avatar
henseyseries3 has donated!
Aslong as you fit the usual size tyre ie 175/50/14 185/50/14 195/45/14 you shouldn’t notice any difference in the speedo I never have anyway
Likes markf, Eklipze3k liked this post
1995 Cinquecento Sporting 1242 8v
2006 Mjet GP
1968 Series 2A Landrover
henseyseries3 is offline Reply With Quote Quote
Old 13-06-2018   #4
The speedo on my cinq with standart 13s was reading way under comared to the speed showed on the sat nav. When I put 14s from sei abarth the speedo reading was within 1-2 km from the satnav reading so it pretty much made it more accurate than it used to be
kingsizef40 is offline Reply With Quote Quote
Old 13-06-2018   #5
chris3234 has donated!
Quote Originally Posted by kingsizef40 View Post
It's normal for a car to read 4-5mph/kph under they are calibrated that way insure your not going faster then you actually are even with very worn tires ect
chris3234 is offline Reply With Quote Quote
Thread Tools
(Tu) speedo adjustment PRiiM3 Cinquecento / Seicento 7 27-04-2010 18:22
