Well, after telling all my family and friends last week that my £150 Sei is my fave car ive owned (in 40 odd cars) it decided to let me down last night and the temp gauge went upto 118 degrees (it runs a scanguage2).
No mayo, no smoke, no odd noises, no loss in power, no bubbling coolant (or brown water in this case...) intake temps of 21 degrees, water present in the system, no leaks, oil in the system.
the temp went up quicker than normal, and fan came on at 97 as usual if stuck in heavy traffic, but even with the fan on and the heaters on full pelt (heat coming out warm) the temp continued to rise.
tried again today, and turned it off at 101 degrees to avoid risking any damage.
im thinking themostat is stuck? (normally when heating up it gets to 92 or so then drops to 85 (stat opening) then hovers around 90 ish.
anyone else had this problem?
cheers in advance
cheers in advance
