Hi
My son has been given a seicento sporting with a short mot to use
It has developed a fault
It will start for about 2 seconds then stop
I have bought a spares car & swapped Ecu, coil packs, plugs, leads, water temp sensor, crank sensor, top dead centre sensor, lambda sensor( lower one) inertia switch, throttle body,
the fuel pump makes a noise when the key is turned, fuel is being delivered to the fuel rail.
Key symbol goes out on the dashboard when starting.
Thanks in advance Dan
