TurboCinqy1250
Member
A few days I decided to get my car on a dyno to get the ignition and AFR on the whole map right. And today was the day.
The area in lower revs was very bad but the higer revs where ok.
At the first test run the car delivered 118WHP and 160 (wheel)Nm Torque.
After a while the big bumps were gone and they could set the ignition.
He stepped on the throttle and I gave in the right values.
The ignition settings didn't have a large effect on the end power, only on the lower revs, just like the AFR settings.
The Ignition on FT is about 10 degrees retarded and the Exhaust temp is about 60 degrees lower.
It ended up with
121 WHP and 178 Nm torque and that equil to 140BHP and about 205Nm Torque. @ near 1 bar, 14,5 PSI
The line is quite flat after 5000rpm and I think there is a little flow problem above this revs. So I need some mods and go to the 150 WHP or more.
I don't have the last runs on the compu yet. They will send them by email.
This should be a graph before and after the dynoruns.
The car drove about 40km on the dyno
before
almost at the end
accelration run
pic
http://members.lycos.nl/turbocinqy/forums/HT-Cinqdyno12-11-2005.WMV
http://members.lycos.nl/turbocinqy/forums/HT-Cinqdyno12-11-2005-2.WMV
Todays (13 nov) G-tech plot:
Before dyno and after dyno.
It ended up with
before
almost at the end
accelration run
pic
