gl1200
- Jan 27, 2008
- 14
- 3
background info,
lost a core plug and severely overheated, resulting in headgasket failure,
head skimmed and fitted with new cambelt w/pump kit
engine hard to start but when started would not rev above 2400, and very lumpy/misfiring,
compression is 190 on all cylinders
fuel pump working,
so far have changed/this week
Crank sensor
Cam sensor
plugs/leads/coils
knock sensor
lambda
sent ecu away for test, came back clean
problem= no spark,
it did try to fire but not now just spins
where do I go now please,
Alan,
fuel pump working,
Crank sensor
Cam sensor
plugs/leads/coils
knock sensor
lambda
problem= no spark,
Alan,
